Efficient printing
With automatic duplexing and a high-speed output of 30 ppm, this printer is designed to boost productivity in any work environment. Its ability to print on both sides of the paper reduces paper usage and provides a professional look to all documents. -
High-quality output
Achieve crisp, clear, and detailed prints with a maximum resolution of 1200 x 1200 DPI. Whether printing business documents or reports, the quality of the output is consistently impressive. -
Versatile media handling
Catering to a wide range of media sizes from A6 to A4 and types including bond paper, envelopes, labels, and recycled paper, this printer meets diverse printing needs. The inclusion of a 250-sheet input tray and a manual feed slot enhances its flexibility for various printing tasks. -
Advanced connectivity
Equipped with USB 2.0 and Wi-Fi interfaces, along with Brother Mobile Connect, this printer offers convenient wireless printing and easy integration into any network. Its comprehensive security features ensure safe and secure document handling. -
Eco-friendly design
Certified by ENERGY STAR and Blue Angel, this printer is recognized for its energy efficiency and reduced environmental impact. It operates quietly, with a sound emission as low as 30 dBA in idle mode, making it suitable for any office setting.
- Brother HL-L2400DWE - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Bundled Services
- 4 months EcoPro subscription
- 7.1 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 15 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution Class (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Wi-Fi(n)
- RAM Installed (Max)
- 64 MB
- Media Type
- Plain paper, thick paper, thin paper, recycled paper, bond paper, labels, envelopes, thicker paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Recommended Monthly Volume
- Up to 2500 pages
- Networking
- Print server
- System Requirements
- Google Chrome OS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64 bits), Microsoft Windows Server 2016 (64-bit), Microsoft Windows Server 2019 (64-bit), Microsoft Windows Server 2022, Windows 10 Education (32/64 bits), Windows 10 Enterprise (32/64 bits), Windows 10 Home (32/64 bits), Windows 10 Pro (32/64 bits), Windows 11 Education, Windows 11 Enterprise, Windows 11 Home, Windows 11 Pro
- 35.6 cm x 36 cm x 18.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Bundled Services
Printer
- Print Speed
- Built-in Devices
- 1 line LCD display
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 8.5 sec
- Media Handling
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), ANSI A (Letter) (216 x 279 mm), JIS B5 (182 x 257 mm), B5 (190 x 250 mm), A5 (148 x 210 mm), JIS B6 (128 x 182 mm), A6 (105 x 148 mm), Executive (184 x 267 mm), 195 x 270 mm, 76.2 x 127 mm, 215.9 x 355.6 mm
- Envelope Sizes
- Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 230 g/m²
- 250 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray: 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 230 g/m² , Output tray: 1 - 150 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- Up to 2500 pages
- Networking
- Print server
- Remote Management Protocol
- HTTP, IPP, SMTP
- Wi-Fi Direct, WEP, WPA2-PSK, WPA3-SAE, WPA-PSK, TKIP, AES, SMTP, SSL, TLS, SNMP 3, 802.1x, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, POP3, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure key management
- Connections
- 1 x USB 2.0
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 15000 pages 1 page per job - Brother DR2510
- Power Device
- Power supply - internal
- 440 Watt
- Power Consumption Stand by
- 43 Watt
- Power Consumption Sleep
- 3.8 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 48 dBA
- Sound Emission (Quiet Mode)
- 44 dBA
- 35.6 cm
- 36 cm
- 18.3 cm
- 7.1 kg
- Width (Shipping)
- 43.8 cm
- Depth (Shipping)
- 28.3 cm
- Height (Shipping)
- 51.9 cm
- Weight (Shipping)
- 8.2 kg
