Wired and Wonderful - The Compact Mono Laser Printer from Brother ticks all the boxes
Key Features:
- This network-ready compact Mono Laser printer is ideal for a small office. From a small footprint the HL-2360DN is capable of making a big impact on a range of mono print requirements.
- With print speeds of up to 30 ppm and a 250 sheet paper tray you can spend more time working on the things that matter.
- You needn't leave your desk either - print from anywhere using the Brother iPrint and Scan app, Google Cloud Print, Apple AirPrint or Wi-Fi Direct.
- Double-Sided printing and optional cost-effective, high-yield toner cartridges mean that your effiiciency extends beyond just the time saving - reduce unnecessary waste and costs with the HL-L2360DN.
- Comes with Toner in the box (for up to 700 pages)
- Brother HL-L2360DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 6.9 kg
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- RAM Installed (Max)
- 32 MB
- Language Simulation
- PCL 6
- Media Type
- Plain paper, bond paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Recommended Monthly Volume
- 250 - 2000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits), Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- Microsoft Certification
- Compatible with Windows 7
- 35.6 cm x 36 cm x 18.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 2400 x 600 dpi
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
- PCL 6
- Media Handling
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 250 - 2000 pages
- Networking
- Print server
- WEP, WPA-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages - Brother DR2300
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 50 dBA
- Sound Emission (Quiet Mode)
- 45 dBA
- 35.6 cm
- 36 cm
- 18.3 cm
- 6.9 kg
- Width (Shipping)
- 44.1 cm
- Depth (Shipping)
- 28.6 cm
- Height (Shipping)
- 50.4 cm
- Weight (Shipping)
- 8 kg
