Brother HL-4150CDN Colour Laser Printer
Quicklinx: 79MKWS00 Mfr#: HL4150CDNZU1
The powerful HL-4150CDN is packed with features that make office life easier.
Print speeds of 24ppm and the ability to print direct from a USB drive saves you time, while automatic double-sided printing can keep paper costs down. Plus the low power consumption could make a noticeable difference to your energy bills.
Protect your most confidential documents with data encryption and Brother's Secure Print feature – just activate the HL-4150CDN using your personal PIN code when you're ready to print.
And the expandable multipurpose tray means this stylish and reliable printer is prepared for any job.
  • Fast color output
    With a print speed up to 25ppm in both color and black, you no longer have to wait for brilliant color output.
  • Easily print two-sided documents
    Using the duplex printing feature, you can help reduce your printing costs and produce two-sided documents, presentations and brochures.
  • USB direct interface
    Print PDF and JPEG files directly from your USB flash memory drive without connecting to your PC.
  • Flexible paper handling
    Use the 250-sheet capacity paper tray for letter or legal paper; plus, there's a 50-sheet capacity multi-purpose tray for envelopes or thicker media.
Brother HL-4150CDN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
220 mm x 406.4 mm
Print Speed
Up to 24 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - colour - A4 (210 x 297 mm) , Up to 7 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 7 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB, LAN, USB host
400 MHz
RAM Installed (Max)
128 MB (384 MB) - DDR2 SDRAM
Language Simulation
PCL 6, XPS, BR-Script3, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Print server - Ethernet, Fast Ethernet - integrated
Linux, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.6.x, Microsoft Windows Server 2003 R2 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
41 cm x 48.6 cm x 31.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Fonts Included
66 x PCL 6 , 66 x PostScript 3 , 12 x bitmapped PCL , 13 x barcode
Media Handling
400 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Technology / Form Factor
DDR2 SDRAM
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
220 mm x 406.4 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets weight: 60 g/m² - 163 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Print server - integrated
Network / Transport Protocol
TCP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, RARP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, FTP, TFTP
Security Protocols & Features
Kerberos, Secure Print, SSL, LEAP, TLS, 802.1x
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
Power supply - internal
560 Watt
Power Consumption Stand by / Sleep
65 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Idle)
33 dB
Sound Emission (Operating)
57 dB
41 cm
48.6 cm
31.3 cm
21 kg
Width (Shipping)
65 cm
Depth (Shipping)
57.4 cm
Height (Shipping)
52.1 cm
79MK Brother TN320BK Black Toner Cartridge 2.5K In Stock £46.92
79MK Brother TN320C 1.5k Cyan Toner In Stock £64.07
79MK Brother TN320M 1.5k Magenta Toner In Stock £64.07
79MK Brother TN320Y 1.5k Yellow Toner In Stock £64.07
79MK Brother TN320C Cyan Toner Cartridge In Stock £64.07
79MK Brother TN325C - Toner cartridge - 1 x cyan - 3500 pages In Stock £113.16
79MK Brother TN325m - Toner cartridge - 1 x magenta - 3500 pages In Stock £113.16
79MK Brother TN325Y - Toner cartridge - 1 x yellow - 3500 pages In Stock £113.16
