The Brother HL-1210W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
                Efficient connectivityWith both USB 2.0 and Wi-Fi interfaces, the Brother HL-1210W offers flexible connectivity options, allowing for easy setup and sharing across multiple devices.
                High-quality printingLeveraging Brother's HQ1200 image enhancement technology, this printer delivers sharp, high-resolution monochrome prints at 2400 x 600 DPI, ensuring clear and detailed documents.
                Rapid outputDesigned for efficiency, the HL-1210W boasts a first print out time of just 10 seconds and a maximum printing speed of 20 pages per minute, minimizing wait times and boosting productivity.
                Versatile media handlingAccommodates a wide range of media sizes from A4 to Legal, and types including plain and recycled paper, making it suitable for various printing needs.
                Eco-friendly operationWith a power consumption of just 0.7 watts in sleep mode, the HL-1210W is energy-efficient, helping to reduce electricity costs and environmental impact.
- Brother HL-1210W - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 4.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 148 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Interface
- USB 2.0, Wi-Fi(n)
- RAM Installed (Max)
- 32 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, recycled paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Recommended Monthly Volume
- 250 - 1800 pages
- System Requirements
- Linux, Android, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple iOS, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2008 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Windows Phone
- 2-year warranty
- 34 cm x 23.8 cm x 18.9 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- 2400 x 600 dpi
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
- Media Handling
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 148 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 216 x 355.6 mm, 148 x 148 mm
- Media Weight
- 65 g/m² - 105 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m²
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 250 - 1800 pages
- Remote Management Protocol
- TFTP
- WEP, WPA-PSK, WPA2-PSK, TKIP, AES
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- Power Device
- Power supply
- 380 Watt
- Power Consumption Stand by
- 40 Watt
- Power Consumption Sleep
- 0.7 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 2 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 51 dBA
- 34 cm
- 23.8 cm
- 18.9 cm
- 4.6 kg
- Width (Shipping)
- 41.5 cm
- Depth (Shipping)
- 30.3 cm
- Height (Shipping)
- 32.4 cm
- Weight (Shipping)
- 5.5 kg
|  | Brother Drum Unit 10K | In Stock | £47.71 |
|  | Brother Toner Cartridge | In Stock | £30.87 |
