Brother HL-1210W Mono Laser Printer
Quicklinx: 9X78WS00 Mfr#: HL1210WZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Laser
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£93.24 ex VAT
£111.88 inc VAT
The Brother HL-1210W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
  • Efficient connectivity
    With both USB 2.0 and Wi-Fi interfaces, the Brother HL-1210W offers flexible connectivity options, allowing for easy setup and sharing across multiple devices.
  • High-quality printing
    Leveraging Brother's HQ1200 image enhancement technology, this printer delivers sharp, high-resolution monochrome prints at 2400 x 600 DPI, ensuring clear and detailed documents.
  • Rapid output
    Designed for efficiency, the HL-1210W boasts a first print out time of just 10 seconds and a maximum printing speed of 20 pages per minute, minimizing wait times and boosting productivity.
  • Versatile media handling
    Accommodates a wide range of media sizes from A4 to Legal, and types including plain and recycled paper, making it suitable for various printing needs.
  • Eco-friendly operation
    With a power consumption of just 0.7 watts in sleep mode, the HL-1210W is energy-efficient, helping to reduce electricity costs and environmental impact.
Brother HL-1210W - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
4.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
148 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
USB 2.0, Wi-Fi(n)
RAM Installed (Max)
32 MB
Language Simulation
Windows GDI driver
Media Type
Plain paper, recycled paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Recommended Monthly Volume
250 - 1800 pages
Linux, Android, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple iOS, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2008 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Windows Phone
34 cm x 23.8 cm x 18.9 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
2400 x 600 dpi
Brother HQ1200
First Print Out Time B/W
10 sec
Language Simulation
Windows GDI driver
Media Handling
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
148 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 216 x 355.6 mm, 148 x 148 mm
Media Weight
65 g/m² - 105 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m²
Output Trays Capacity
50 sheets
Duty Cycle
250 - 1800 pages
Remote Management Protocol
TFTP
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, TKIP, AES
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages
Power supply
380 Watt
Power Consumption Stand by
40 Watt
Power Consumption Sleep
0.7 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
51 dBA
34 cm
23.8 cm
18.9 cm
4.6 kg
Width (Shipping)
41.5 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
32.4 cm
Weight (Shipping)
5.5 kg
9X78 Brother Drum Unit 10K In Stock £47.77
9X78 Brother Toner Cartridge In Stock £32.19
Type: Printer
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
Stock Status: While stocks last
Stock Status: Clearance
