Brother HL-1110 A4 Mono USB Laser Printer
Quicklinx: 96VJWS00 Mfr#: HL1110ZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
More than 50 In Stock
£72.15 ex VAT
£86.58 inc VAT
If you're pushed for space and time in your home office, Brother's compact HL-1110 is the ideal solution.
With up to 20ppm print speed, you won't be kept waiting – and as it delivers up to 600dpi resolution, you don't have to compromise print quality for speed. There's also a full-speed USB 2.0 interface so you can plug in and then print in minutes.
And if you've ever found yourself constantly refilling with paper, replacing toner or sorting paper jams, you'll surely appreciate the HL-1110's 150-sheet paper tray, 1,000 page cartridges and innovative anti-jam technology.
Brother HL-1110 - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
4.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
USB 2.0
200 MHz
RAM Installed (Max)
1 MB
Media Type
Plain paper, recycled paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x
Microsoft Certification
Compatible with Windows 7
34 cm x 23.8 cm x 18.9 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0
2400 x 600 dpi
First Print Out Time B/W
10 sec
Media Handling
200 MHz
RAM
RAM Installed (Max)
1 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), Folio (216 x 330 mm)
Media Weight
65 g/m² - 105 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets weight: 65 g/m² - 105 g/m²
Output Trays Capacity
50 sheets
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 10000 pages - Brother DR1050
Power supply - internal
Frequency Required
50/60 Hz
380 Watt
Power Consumption Stand by
40 Watt
Power Consumption Sleep
0.5 Watt
Environmental Standards
ENERGY STAR
10 °C
32.5 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
51 dBA
34 cm
23.8 cm
18.9 cm
4.5 kg
96VJ Brother Drum Unit 10K In Stock £46.29
96VJ Brother Toner Cartridge In Stock £29.93
Type: Printer
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
