Brother FAX-T104
Brother FAX-T104
Quicklinx: 3VZMWS00 Mfr#: FAXT104U1
The FAX-T104 has been specifically designed to fit perfectly in any home.
Easy to use and simple to install, this versatile machine combines sharpness and quality with a whole host of fax management features – helping to make your communications more efficient.
With a 25-sheet memory back up and 104 quick dial locations, the FAX-T104 enables you to connect and share information quickly. The clear print quality adds that all-important touch of professionalism, while the adjustable volume makes sending and receiving faxes less of a headache.
Brother FAX-T104 - fax / copier - B/W
Fax / copier
Fax Type
G3 - plain paper
Printing Technology
Thermal transfer (monochrome)
Max Fax Transmission Speed
9.6 Kbps
Original Size
148 mm width (min) - 216 mm width (max)
Original Type
Sheets
Document Feeder Capacity
10 sheets
Media Type
Plain paper
Standard Media Capacity
30 sheets
AC 230 V (50/60Hz)
30.2 cm x 26.7 cm x 34 cm
2.7 kg
1-year warranty
Fax / copier
Fax Type
Plain paper
Printing Technology
Thermal transfer - monochrome
Display
1 line x 16 characters
Standard Memory
512 KB 512 KB
Copying
Max Document Enlargement
150%
Max Document Reduction
50%
Preset Enlargements
150%, 120%, 125%
Preset Reductions
50%, 93%, 87%, 75%
Maximum Copies
99
Fax Machine
Compatibility
G3
Max Transmission Speed
9.6 Kbps
Handset
Corded handset
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
4 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
104 stations
Document & Media Handling
Min Original Size
148 mm width
Max Original Size
216 mm width
Original Type
Sheets
10 sheets
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Plain paper
30 sheets
Paper cassette - 30 sheets - A4 (210 x 297 mm) , ADF - 10 sheets size: 148 mm width - 216 mm width
AC 230 V (50/60Hz)
160 Watt
Power Consumption Standby
4.4 Watt
Limited warranty - 1 year - on-site
30.2 cm
26.7 cm
34 cm
2.7 kg
3VZM Brother T104/T106 FAX CART INC 144 SHT RIBB In Stock £15.48
