The genuine 4 colour Brother DR-320CL drum unit is designed to cover your imaging needs for black and colour prints. The DR320CL 4 colour drum produces superb image quality when used inside your colour laser printer. Designed to handle all your imaging requirements, this original Brother DR-320CL drum cartridge works with speed and accuracy to produce rich, vibrant graphics. The convenient Brother DR320CL imaging drum is easy to install in one piece. Featuring a robust and innovative design, this high performing Brother DR320CL image drum integrates the CMYK components into one unit. The DR-320 drum can refresh your entire imaging system, enabling you to extend the life of your laser printer for approximately 25,000 pages
- Brother DR320CL - original - drum kit
- Product Type
- Drum kit
- Printing Technology
- Laser
- Yield
- Up to 25000 pages ISO/IEC 19798
- Compatible with
- Brother DCP-9055CDN, DCP-9270CDN, HL-4140CN, HL-4150CDN, HL-4570CDW, HL-4570CDWT, HL-L9310CDWMT, MFC-9460CDN, MFC-9465CDN, MFC-9970CDW
Consumable
- Consumable Type
- Drum kit
- Laser
- Yield
- Compatible with
