Print, scan and copy more efficiently with the DCP-L5500DN. Fast print and scan speeds alongside versatile paper handling options gives you greater efficiency and outstanding results every time. A user friendly 9.3cm touchscreen helps to make this machine the ideal print partner for your office.
Key Features
- Super-fast print speeds of up to 40ppm and scan speeds of up to 24ipm.
- Combined paper input of 300 sheets.
- Automatic 2-sided printing.
- High-Yield Replacement Cartridges - Optional high yield 8,000 page toner cartridge.
- Intuitive 9.3cm touchscreen LCD display.
- High speed wired (10Base-T/100 Base-TX) interface and USB 2.0 connectivity.
Maximise Performance & Reduce Print Spend
First page out time is just 7.5 seconds followed by a fast print speed of up to 40ppm. Standard paper input is 570 expandable to 1,610. As well as improved performance, reducing print spend is something that every business looks at - with the optional 12,000 page super high yield toner your overall printing costs will reduce dramatically.
Better Reliability
Perform for longer, with a recommended monthly volume of up to 5,000 pages to meet the demands of the busy office. Plus, units have been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
Design improvements include an 40 page auto document feeder that enables high speed 2-sided scanning straight into a document management system. Along with a more intuitive 9.3cm touchscreen and user-friendly interface and improved support for different media and connectors to popular cloud based services such as Microsoft SharePoint , it’s just what busy workgroups have been waiting for.
Tighter Security
The DCP-L5500DN has the highest levels of security. Meeting requirements with secure function lock 3.0, Active directory connectivity and Internet Protocol Security (IPsec). Plus, the range features Print Archive, Secure Reset.
Flexible print solutions from Brother
Brother print solutions are exciting packages of innovation designed to make doing business easier. By offering a range of print solutions to help your customers maximise print efficiency and minimise costs, we help you add value to every printer.
Eco-friendly
The DCP-L5500DN 3-in-1 is awarded with the stringent German Blue Angel, Nordic Swan and Energy Star environmental standards. That means that this printer is classed as particularly energy efficient. Also, separate toner and drum mean you can help protect the environment and lower costs at the same time.
Fast, high-quality printing and copying
With a print speed of up to 42 pages per minute (based on one-sided printing, change from default setting required), this multi-function copier is ideal for busy offices. -
Cost-efficient output
Help lower your operating costs via a high-yield 8,000-page replacement toner cartridge. -
Flexible network connectivity
Built-in Ethernet interface allows you to share the DCP-L5500DN with multiple users on your network. -
Flexible paper handling
Easily handle your large print jobs via an adjustable 250-sheet capacity paper tray and 50-sheet capacity multi-purpose tray. Additional optional paper trays are available in 250-sheet or 520-sheet capacities enabling users to configure the multi-function copier with multiple trays in a way that best meets their application requirements - up to 1,340-sheet total capacity. -
Automatic duplex (two-sided) printing
Help save paper and create two-sided documents with automatic duplex printing. Also, create two-sided output from one-sided originals when copying. -
40-page capacity auto document feeder
Use for unattended copying or scanning of multi-page documents (up to legal size). -
Advanced scanning capabilities
Supports multiple scan-to destinations such as E-mail, SSH Server (SFTP), USB, SharePoint, Cloud Services, and Network Folder (CIFS) to easily adapt to your customized workflow. -
Convenient mobile device printing and scanning
Print from your mobile device via: AirPrint, Google Cloud Print 2.0, Mopria, Brother iPrint&Scan and Cortado Workplace. Plus, wirelessly scan to your mobile device with the Brother iPrint&Scan app. -
Walk-up printing and scanning
A USB Host is located on the front of the machine for printing files from or scanning files to your USB flash memory drive. -
Advanced security features
Active Directory support for network user authentication to help protect against unauthorized access to the device. Other security features include: Secure Function Lock, LDAP, SSL/TLS, and more. -
Outstanding customer support
Online, call, or live chat - free support for the life of your printer.
- Brother DCP-L5500DN - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Recommended Monthly Volume
- 3500 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 43.5 cm x 48.6 cm x 42.7 cm
- 16.4 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty
- Laser - monochrome
- 3500 pages
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, IBM Proprinter, BR-Script 3, PDF 1.7, XPS, EPSON FX
- First Print Out Time B/W
- 7.2 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 40 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 spm (A4) - B/W duplex , Scanning: up to 24 ipm - B/W , Scanning: up to 20 ipm - colour
- 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
- Kerberos, SSL, TLS, IPsec, APOP
- Operating System Support
- Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
- Voltage Required
- 645 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 7.5 Watt
- First Copy Out Time B/W
- 9.2 sec
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years
- 43.5 cm
- 48.6 cm
- 42.7 cm
- 16.4 kg
- Shipping Width
- 54.5 cm
- Shipping Depth
- 52 cm
- Shipping Height
- 64.1 cm
- Shipping Weight
- 19.7 kg
- Sound Emission
- 35 dBA (idle) / 54 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother TN-3430 Black Standard Yield Toner | In Stock | £59.57 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £102.51 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £120.18 |
