Brother DCP-L8410CDW Colour Laser Multifunction Printer
Quicklinx: CTP3WS00 Mfr#: DCPL8410CDWZU1
Hurry, only 3 left in stock!
£355.62 ex VAT
£426.74 inc VAT
The improved DCP-L8410 packs a powerful punch, offering professional quality color printing for today's demanding business environment. Not only that, but it has low total cost of ownership (TCO) and improved connectivity - including scan and print compatibility with mobile devices and cloud-based services. That makes it ideal for connecting with mobiles and tablets, embracing the 'bring your own device' revolution in the workplace.
Key features
  • High speed 31ppm colour & mono
  • 28ipm scan speed colour & mono
  • 9.3cm touchscreen
  • 300 sheet paper capacity
  • USB Wireless and Gigabit Wired network
  • 3000 Black and 1800 Cyan Magenta & Yellow Toners Inbox
  • Efficient connectivity
    With a variety of interfaces including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print 2.0, this device ensures seamless connection and printing from virtually anywhere.
  • High-quality printing
    Achieve professional, high-resolution prints with up to 2400 x 600 DPI for both black and white and color documents, complemented by automatic duplexing for efficient two-sided printing.
  • Versatile media handling
    Supports a wide range of media sizes from A4 to Legal, and types including envelopes, labels, plain paper, and more, making it suitable for various printing needs.
  • Advanced scanning capabilities
    Offers detailed scanning with an optical resolution of 1200 x 2400 DPI, color depth of 24-bit, and interpolated resolution up to 19200 x 19200 DPI, ensuring clear and vibrant digital copies.
  • Eco-friendly design
    ENERGY STAR certified and Blue Angel compliant, this printer operates efficiently, with a low power consumption in sleep mode of just 10 W, reducing environmental impact and operational costs.
Brother DCP-L8410CDW - multifunction printer - colour
Multifunction printer
United Kingdom
Printing Technology
Laser (colour)
Recommended Monthly Volume
3000 pages
Max Copying Speed
Up to 31 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to USB host
AC 230 V (50/60Hz)
43.5 cm x 52.6 cm x 53.9 cm
27.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - colour
3000 pages
Display Diagonal Size
3.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
United Kingdom
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Scanning Resolution Details
1200 x 600 dpi - ADF , 1200 x 2400 dpi - flatbed
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Scanning: up to 28 ppm - B/W , Scanning: up to 28 ppm - colour , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
17 sec
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x drum - up to 50000 pages 3 pages per job , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years , Limited warranty - 1 year - on-site
43.5 cm
52.6 cm
53.9 cm
27.6 kg
Shipping Width
66.3 cm
Shipping Depth
54.2 cm
Shipping Height
65.4 cm
Shipping Weight
33.3 kg
Sound Emission
44 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
CTP3 Brother Waste Toner Pack In Stock £14.91
Type: Printer / copier / scanner
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
