Efficient connectivity
With a versatile range of interfaces including USB 2.0 and Wi-Fi(n), alongside comprehensive security protocols such as AES, SSL, and WPA3-SAE, this device ensures a secure and flexible connection for all office environments. -
High-quality printing
Achieve professional, vivid color prints with a maximum resolution of 600 x 2400 DPI. Automatic duplexing enhances productivity by facilitating double-sided printing without manual intervention. -
Comprehensive media handling
Supports a wide array of media sizes from A4 to Legal, and types including envelopes, glossy paper, and labels, making it ideal for diverse printing needs. The input tray accommodates up to 250 sheets, ensuring efficient handling of large print jobs. -
Advanced scanning capabilities
Features an optical resolution of 1200 x 1200 DPI for high-quality scans. The inclusion of scan to email, folder, and network options enhances workflow efficiency by simplifying document distribution. -
Eco-friendly design
ENERGY STAR certified and Blue Angel compliant, this device meets strict energy efficiency and environmental standards, reducing operational costs and supporting sustainability initiatives.
- Brother DCP-L3520CDWE - multifunction printer - colour - with 4 months EcoPro subscription
- Multifunction printer
- Bundled Services
- 4 months EcoPro subscription
- Printing Technology
- LED (colour)
- Recommended Monthly Volume
- Up to 3000 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
- Max Printing Resolution Class
- Scanning
- 1200 x 1200 dpi
- Original Type
- Sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, thin paper, thick paper, recycled paper, bond paper, labels, envelopes, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- Office Machine Features
- Scan to e-mail, scan to OCR, scan to image, scan to folder, scan to network folder, scan to FTP, scan to SharePoint, scan to SMB
- 41 cm x 44.4 cm x 35.5 cm
- 18.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Bundled Services
- LED - colour
- Up to 3000 pages
- Display
- 2 lines
- Display Features
- LCD display
- Interface
- USB 2.0, Wi-Fi(n)
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 5c, PCL 6 (XL 3.0), BR-Script 3, PDF 1.7
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
Document & Media Handling
- Original Type
- Sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), JIS B6 (128 x 182 mm), Folio (203 x 330 mm), 195 x 270 mm, 76.2 x 116 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - 216 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - B/W duplex , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - colour duplex
- 1 x USB 2.0
- Wi-Fi Direct, WEP, WPA-PSK, TKIP, AES, WPA2-PSK, WPA3-SAE, APOP, SMTP, SSL, TLS, POP3, SNMP 3, 802.1x, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, Kerberos, IPsec, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure function lock v3, Secure Print, setting lock, syslog reporting, store print log
- 460 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 10 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 500 pages ISO/IEC 19798 , 1 x drum - up to 20000 pages 1 page per job - Brother DR248CL , 1 x belt - up to 50000 pages 2 pages per job - Brother BU229CL , 1 x waste toner collector - up to 50000 pages 5 pages per job - Brother WT229CL
- Nordic Swan Ecolabel
- ENERGY STAR Certified
- Blue Angel Compliant
- 41 cm
- 44.4 cm
- 35.5 cm
- 18.6 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 53.6 cm
- Shipping Height
- 49.7 cm
- Shipping Weight
- 21.8 kg
- Sound Emission
- 46 dBA (operating)
