Brother DCP-L3520CDWE A4 Colour Laser MFP
Quicklinx: HX0NWS00 Mfr#: DCPL3520CDWEZU1
18 In Stock
£279.83 ex VAT
£335.79 inc VAT
  • Efficient connectivity
    With a versatile range of interfaces including USB 2.0 and Wi-Fi(n), alongside comprehensive security protocols such as AES, SSL, and WPA3-SAE, this device ensures a secure and flexible connection for all office environments.
  • High-quality printing
    Achieve professional, vivid color prints with a maximum resolution of 600 x 2400 DPI. Automatic duplexing enhances productivity by facilitating double-sided printing without manual intervention.
  • Comprehensive media handling
    Supports a wide array of media sizes from A4 to Legal, and types including envelopes, glossy paper, and labels, making it ideal for diverse printing needs. The input tray accommodates up to 250 sheets, ensuring efficient handling of large print jobs.
  • Advanced scanning capabilities
    Features an optical resolution of 1200 x 1200 DPI for high-quality scans. The inclusion of scan to email, folder, and network options enhances workflow efficiency by simplifying document distribution.
  • Eco-friendly design
    ENERGY STAR certified and Blue Angel compliant, this device meets strict energy efficiency and environmental standards, reducing operational costs and supporting sustainability initiatives.
Brother DCP-L3520CDWE - multifunction printer - colour - with 4 months EcoPro subscription
Multifunction printer
Bundled Services
Printing Technology
LED (colour)
Recommended Monthly Volume
Up to 3000 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 1200 dpi
Original Type
Sheets
Media Size
76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, thin paper, thick paper, recycled paper, bond paper, labels, envelopes, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to OCR, scan to image, scan to folder, scan to network folder, scan to FTP, scan to SharePoint, scan to SMB
41 cm x 44.4 cm x 35.5 cm
18.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Bundled Services
Printing Technology
LED - colour
Up to 3000 pages
Display
2 lines
Display Features
LCD display
USB 2.0, Wi-Fi(n)
Standard Memory
512 MB
Copying
Max Copying Speed
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 5c, PCL 6 (XL 3.0), BR-Script 3, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Document & Media Handling
Original Type
Sheets
Min Media Size
76.2 x 116 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), JIS B6 (128 x 182 mm), Folio (203 x 330 mm), 195 x 270 mm, 76.2 x 116 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - 216 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - B/W duplex , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - colour duplex
1 x USB 2.0
Security Protocols & Features
Wi-Fi Direct, WEP, WPA-PSK, TKIP, AES, WPA2-PSK, WPA3-SAE, APOP, SMTP, SSL, TLS, POP3, SNMP 3, 802.1x, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, Kerberos, IPsec, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure function lock v3, Secure Print, setting lock, syslog reporting, store print log
460 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
Consumables Included
1 x toner cartridge (black) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 500 pages ISO/IEC 19798 , 1 x drum - up to 20000 pages 1 page per job - Brother DR248CL , 1 x belt - up to 50000 pages 2 pages per job - Brother BU229CL , 1 x waste toner collector - up to 50000 pages 5 pages per job - Brother WT229CL
Nordic Swan Ecolabel
ENERGY STAR Certified
Blue Angel Compliant
41 cm
44.4 cm
35.5 cm
18.6 kg
Shipping Width
49.7 cm
Shipping Depth
53.6 cm
Shipping Height
49.7 cm
Shipping Weight
21.8 kg
Sound Emission
46 dBA (operating)
Type: Printer / copier / scanner
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
