Brother DCP-L2627DWE Efficient 3-in-1 A4 Mono Laser Printer
Quicklinx: HX0LWS00 Mfr#: DCPL2627DWEZU1
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Max Paper Size: 215.9 x 355.6 mm
42 In Stock
£144.92 ex VAT
£173.90 inc VAT
  • Effortless printing
    Make your day easier and your printing effortless, with a simple set up and 5 GHz Wi-Fi or USB connection. This efficient DCP-L2627DWE is a breeze to operate using the easy-to-navigate control panel.
  • Print longer
    The DCP-L2627DWE keeps your printing costs down using a separate drum and toner unit, and the 700 pages inbox toner supporting your higher print volume needs.
  • The perfect partner
    High-quality print technology ensures that your output is flawless and professional every time. The expertly designed DCP-L2627DWE has a high-capacity paper input and output tray allowing you to print for longer, while the compact and quiet form enables you to work without interruption in smaller workspaces.
  • Print from anywhere
    With Brother Mobile Connect, you can fully operate your Brother printer from your fingertips. Print and scan documents on the move. You can also personalize your frequently used features and unlock a revolutionary way of printing from your mobile device.
  • Secure by design
    The device offers excellent security features to securely protect your data. Brother's security experts continuously research enhancements to products, solutions and services to proactively ensure all their products are "secure by design". The Brother printer uses triple-layer security at a device, network and document level, adding peace of mind that the integrity of your data is maintained at every step.
Brother DCP-L2627DWE - multifunction printer - B/W - with 4 months EcoPro subscription
Multifunction printer
Bundled Services
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
Up to 2500 pages
Max Copying Speed
Up to 32 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Copying Resolution Class
Up to 600 x 600 dpi
Max Printing Speed
Up to 32 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Scanning
1200 x 1200 dpi
Original Size
Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - 215.9 x 355.6 mm (max)
Media Type
Plain paper, thin paper, thick paper, recycled paper, bond paper, labels, envelopes
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to OCR, scan to image, scan to folder, scan to network, scan to SharePoint
AC 220-240 V (50/60Hz)
41 cm x 39.9 cm x 27.2 cm
10.1 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Bundled Services
Printing Technology
Laser - monochrome
Up to 2500 pages
Display
2 lines x 16 characters
Display Features
LCD display
USB 2.0, Wi-Fi(n)
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 32 ppm
Up to 600 x 600 dpi
Up to 600 x 600 dpi
Maximum Copies
99
Printing
Max Printing Speed
Up to 32 ppm
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
230 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), A5 (148 x 210 mm), JIS B6 (128 x 182 mm), A6 (105 x 148 mm), Executive (184 x 267 mm), 195 x 270 mm, 76.2 x 127 mm, 215.9 x 355.6 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 230 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 32 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 16 spm (A4) - B/W duplex , Copying: up to 32 ppm (A4) - B/W , Printing: up to 34 ppm (Letter A) - B/W (ISO/IEC 24734) , Printing: up to 17 ppm (Letter A) - B/W duplex
1 x USB 2.0
Security Protocols & Features
Wi-Fi Direct, WEP, WPA-PSK, TKIP, AES, WPA2-PSK, WPA3-SAE, SMTP, SSL, TLS, POP3, SNMP 3, 802.1x, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure key management
Operating System Support
Chrome OS, macOS 11, macOS 13, MS Windows Server 2012, MS Windows Server 2012 R2, MS Windows Server 2016, MS Windows Server 2019, MS Windows Server 2022, Windows 10 Education, Windows 10 Enterprise, Windows 10 Home, Windows 10 Pro, Windows 11 Education, Windows 11 Enterprise, Windows 11 Home, Windows 11 Pro
480 Watt
Power Consumption Standby
43 Watt
Power Consumption Sleep
4.1 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 15000 pages 1 page per job - Brother DR2510
Nordic Swan Ecolabel
ENERGY STAR Certified
Blue Angel Compliant
41 cm
39.9 cm
27.2 cm
10.1 kg
Shipping Width
58 cm
Shipping Depth
51.7 cm
Shipping Height
43.4 cm
Shipping Weight
12.6 kg
Sound Emission
30 dBA (idle) / 49 dBA (operating)
10 °C
32.5 °C
20 - 80% (non-condensing)
Functionality: Printer
Functionality: Scanner
Brand: Brother
