Speed up your small office. With this Wi-Fi enabled Mono Laser All-in-one printer, you're free to print and scan from anywhere - compatible with the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct, the DCPL2520DW is one well connected device.
With added All-in-One functions, this machine provides a quick and efficient solution to all small office print, scan and copy requirements. Offering quick print speeds of up to 26ppm and a large 250-sheet paper tray, this compact machine really outperforms its size.
Automatic 2-sided print and optional cost-effective, high-yield toner cartridges help to reduce running costs and waste. For affordability and the freedom of your office, you can't go far wrong with this wireless mono laser All-in-One printer.
- Brother DCP-L2520DW - multifunction printer - B/W
- Multifunction printer
- Localisation
- United Kingdom
- Printing Technology
- Laser (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 26 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Scanning
- 600 x 2400 dpi
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 26.7 cm
- 9.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, Wi-Fi(n)
- Localisation
- United Kingdom
- Standard Memory
- 32 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 26 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, BR-Script 3
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 30-bit
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 13 ppm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, TKIP, AES
- Operating System Support
- Linux, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum
- 40.9 cm
- 39.85 cm
- 26.7 cm
- 9.7 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 41.4 cm
- Shipping Weight
- 12.5 kg
- Sound Emission
- 33 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
