Brother DCP J825DW Colour Inkjet Multifuntion
Quicklinx: 7T55WS00 Mfr#: MFCJ825DWZU1
The MFC-J825DW offers print, copy, scan and fax features and is ideal for the small or home office. Share with multiple computers on a network using the wireless or wired Ethernet connection. The 3.3" touchscreen color LCD display is perfect for interactive and easy to use menu navigation. Access your Facebook, Picasa web albums, Flickr Google Docs and Evernote accounts via the web connect touchscreen interface. Print directly on printable blank DVDs, CDs and Blu-ray discs for personalization. Help save paper with automatic duplex. Unattended fax, copy and scan up to 20-page documents using the automatic document feeder.
  • Flexible wireless and wired interfaces
    It is easy to setup wireless or wired Ethernet networking.
  • 3.3" touchscreen color LCD display
    Edit and enhance images and easily read help menus.
  • Duplex printing
    Create two-sided documents and save paper with duplex printing.
  • Web connect touchscreen
    Access your Facebook, Picasa web album, Flickr Google Docs and Evernote accounts via the web connect touchscreen interface.
  • CD/DVD printing
    Print directly on to your printable blank DVDs, CDs and Blu-ray discs.
Brother MFC-J825DW - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper
Standard Media Capacity
100 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, USB host, Wi-Fi
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail
40.5 cm x 37.8 cm x 18 cm
9.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
Standard Memory
64 MB 64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, Memory Stick Micro (M2), MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth (Internal)
36-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 800 pages
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Fax forwarding, automatic redialing, group dialling, remote reception
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm
100 sheets
50 sheets
Paper cassette - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets , ADF - 20 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 27 ppm (A4) - colour , Printing: up to 12 ipm - B/W , Printing: up to 10 ipm - colour , Copying: up to 23 ppm - B/W , Copying: up to 20 ppm - colour , Copying: up to 23 ipm - colour , Scanning: 3.37 sec (A4) - B/W , Scanning: 3.37 sec (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, IPv4
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
Brother ControlCentre2, Brother MFL-Pro Suite, ScanSoft PaperPort SE 12.0, Brother ControlCenter4, Presto! PageManager 9 for Mac
24 Watt
Power Consumption Standby
6.5 Watt
Power Consumption Sleep
2.5 Watt
Direct Printing Specifications
PictBridge
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years - carry-in
40.5 cm
37.8 cm
18 cm
9.3 kg
Sound Emission
50 dB (operating)
7T55 Brother LC1240BK - Print cartridge - 1 x black - 600 pages In Stock £18.00
7T55 Brother LC1240C - Print cartridge - 1 x cyan - 600 pages In Stock £11.51
7T55 Brother LC1240M - Print cartridge - 1 x magenta - 600 pages In Stock £11.51
7T55 Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages In Stock £14.00
7T55 Brother LC1220 Black/Cyan/Magenta/Yellow Value Pack In Stock £36.44
