Brother DCP-J552DW A4 Colour Inkjet Multifunction Printer
Quicklinx: 9K24WS00 Mfr#: DCPJ552DWZU1
Specifically designed with digitally-connected home users in mind, the DCP-J552DW with print, copy and scan functions delivers the best possible results with the minimum of fuss.
You won't even need to turn on your PC when you can print straight from your media card or mobile device. Plus you can instantly send your work direct to cloud-based services like Microsoft OneDrive, Google Drive, Dropbox, Facebook and Flickr.
The fast and flexible DCP-J552DW also offers double-sided printing and a range of useful scan and copy features that mean you can work smarter – plus the Office Document Creator lets you scan and immediately edit hard copies of your documents in Microsoft Office.
  • Improve productivity and save time
    Featuring high print speeds of 12/10 ppm, time is saved when there are multiple users or large volume printing tasks. Users can utilize their time more efficiently instead of waiting for their printouts.
  • Enjoy lower running costs
    Reduce paper and ink wastage with Brother's duplex (two-sided) printing. Plus, easily produce 2-up and 4-up on a single sheet. This saves paper when viewing drafts or layouts.
  • Professional quality
    The color inkjet series deliver consistent and high quality results with sharp images and crisp text. The multi-function centers offer unique color enhancement designed to optimize your color prints with true to life colors. Brother black pigment ink will provide you with sharp text printing on standard paper. It is water resistant so it will not smudge. You get consistently sharp text every time.
  • Direct printing without a computer
    The direct print feature enables users to print files such as JPEG or printer-ready documents without even using your computer! Print directly from media cards.
Brother DCP-J552DW - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 4.4 ppm (mono) / up to 2.7 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Media Size
89 x 127 mm (min) - ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, plain paper, photo paper, coated paper, glossy paper
Standard Media Capacity
120 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), USB host
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, AOSS
AC 230 V (50/60Hz)
41 cm x 37.4 cm x 16.1 cm
7.8 kg
Microsoft Certification
Compatible with Windows 7
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Features
Touch screen
Standard Memory
64 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
210 nozzles (black), 3 x 210 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Document & Media Handling
Max Original Size
Min Media Size
89 x 127 mm
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, 102 x 152 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
120 sheets
50 sheets
Input tray - 100 sheets size: 98 x 148 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Input tray - 20 sheets size: 89 x 127 mm - 102 x 152 mm weight: 64 g/m² - 220 g/m²
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 27 ppm - colour , Printing: up to 12 ipm - B/W (ISO/IEC 24734) , Printing: up to 10 ipm - colour (ISO/IEC 24734) , Copying: up to 4.4 ipm - B/W , Copying: up to 2.7 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS
Operating System Support
MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
16 Watt
Power Consumption Standby
3.5 Watt
Power Consumption Sleep
0.7 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
41 cm
37.4 cm
16.1 cm
7.8 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
