Wireless Colour Inkjet All-in-One with Duplex
The DCP-J4110DW utilises landscape print technology, feeding through the printer in a landscape format to offer you fast print speeds in a lower profile machine. Print speeds of up to 18ipm (mono) and 16ipm (colour) mean you will not be kept waiting for your documents.
The DCP-J4110DW offers a number of cost saving functions, including automatic 2-sided printing to save paper, and high yield ink cartridges, with yields of up to 1,200 pages for a lower cost per page. All this is achieved without compromising on print quality, ensuring professional looking documents.
Key Benefits
Save time with high speed 18/ 16ipm mono/ colour printing
Flexible paper handling with 150 sheet paper capacity and an A3 Bypass tray
Produce high quality photo's and copies with 4 individual ink cartridges
AirPrintTM and Google Cloud PrintTM ready
Intuitive 4.5cm touch screen LCD enables quick access to cloud services including Google Docs, Facebook, Flickr, Picassa, Dropbox and Evernote
Faster and more secure 802.11n wireless connection or connect to your network via the built-in Ethernet, or to your PC with Hi-Speed USB 2.0
Lower costs with optional high yield supplies and automatic 2-sided printing
In The Box
Consumables: Black, Cyan, Magenta, Yellow ink cartridges
Power Supply Cord: Yes
Quick Set Up Guide: Yes
Software Drivers for Windows and Mac
USB Cable not included
- Brother DCP-J4110DW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 18 ppm (mono) / up to 16 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Scanning
- 2400 x 2400 dpi
- Display
- 1.8"
- Original Size
- Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, coated paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, AOSS
- Power
- AC 230 V (50/60Hz)
- 48 cm x 29 cm x 16.3 cm
- 8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Ink-jet - colour
- Display Diagonal Size
- 1.8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 127 x 203 mm, 102 x 152 mm, 127 x 178 mm, 89 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm
- 150 sheets
- 1 sheet
- 50 sheets
- Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Output tray - 50 sheets
- Speed Details
- Printing: up to 18 ipm - B/W (ISO/IEC 24734) , Printing: up to 16 ipm - colour (ISO/IEC 24734) , Printing: up to 33 ppm - B/W fast , Printing: up to 25 ppm - colour fast , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK, WPS, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 48 cm
- 29 cm
- 16.3 cm
- 8 kg
- Shipping Width
- 56.4 cm
- Shipping Depth
- 24.7 cm
- Shipping Height
- 41.6 cm
- Shipping Weight
- 10.1 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
