Brother DCP-J1800DW All In One Inkjet Printer & Paper Cutter
Quicklinx: HWZYWS00 Mfr#: DCPJ1800DWZU1
£184.21 ex VAT
£221.05 inc VAT
Enjoy this Brother's A4 printer with the ability to automatically print and cut both single-sided and 2-sided A4 paper down to A5 size. The cutting function makes this model a great asset to any home or small business. Create high-quality personalized outputs for any occasion, such as birthday party invitations and vibrant color photo prints. Print resources for your small business; anything from customized menus and signs to invoices or packing labels and the device will automatically cut them down to A5 size.
  • Compact and feature-rich
    The DCP-J1800DW has a feature for everyone in your household or small office to enjoy. Print color photographs, crafts, invitations, delivery notes or address labels, and even print and cut customized marketing materials for your business. Use the automatic document feeder to copy and scan, saving you time. Print wirelessly in vivid color from anywhere and navigate the device easily via the 6.8cm color LCD touchscreen. The DCP-J1800DW is stylish and compact in size and will fit seamlessly into small spaces around your home or office.
  • High printing speeds
    A unique A4 printer, which can also professionally cut A4 to A5. Saving you time and delivering a more consistent output than manual cutting.
  • 6.8cm color LCD touchscreen
    With easy out of the box set up and user-friendly navigation.
  • A4 print speeds
    A4 print speeds along with print and cut with speeds of up to 16.5 ipm, improving your productivity.
  • Colorful prints
    Print directly onto photo paper. Producing vibrant colorful prints.
  • Wireless connectivity
    Print from anywhere, anytime using the Brother Mobile Connect app.
Brother DCP-J1800DW - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Recommended Monthly Volume
50 - 1000 pages
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 17 ipm (mono) / up to 16.5 ipm (colour)
Max Printing Resolution
Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, envelopes, photo paper, glossy paper, cards
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
LAN, USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to OCR, scan to image, scan to folder, automatic cutter, scan to PDF, scan to mobile device
40 cm x 34.3 cm x 17.2 cm
8.3 kg
Enclosure Colour
Grey
3-year warranty with product registration
Printing Technology
Ink-jet - colour
50 - 1000 pages
Display Colour Support
Display Features
Touch screen, LCD display
AirPrint Enabled
Enclosure Colour
Grey
Standard Memory
512 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
N-in-1, Multiple Copy, Sort, Poster Copy
Printing
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
6.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Scanning Resolution Details
1200 x 2400 dpi - flatbed , 1200 x 600 dpi - ADF
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
20 sheets
Max Media Size
A4/Letter
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 102 x 152 mm, 127 x 203 mm, 127 x 178 mm, 89 x 127 mm
Supported Envelope Sizes
International C5 (162 x 229 mm), Com-10 (105 x 241 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm)
150 sheets
50 sheets
Input tray - 150 sheets weight: 64 g/m² - 220 g/m² , ADF - 20 sheets weight: 64 g/m² - 90 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 17 ipm - B/W (ISO/IEC 24734) , Printing: up to 16.5 ipm - colour (ISO/IEC 24734) , Printing: up to 5.5 ipm - B/W duplex (ISO/IEC 24734) , Printing: up to 5.5 ipm - colour duplex (ISO/IEC 24734) , Copying: up to 13 ipm - B/W (ISO/IEC 24735) , Copying: up to 10.5 ipm - colour (ISO/IEC 24735) , Scanning: up to 17 ipm - B/W (ISO/IEC 17991) , Scanning: up to 7 ipm - colour (ISO/IEC 17991)
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
Wi-Fi Direct, SSL, TLS, 802.1x, EAP-MD5, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, WEP, SSID, WPA-PSK, TKIP, AES, WPA2-PSK, IPv4 support, IPv6 support, WPA2-Enterprise, WPA, WPS
21 Watt
Power Consumption Standby
3 Watt
Power Consumption Sleep
0.9 Watt
First Copy Out Time B/W
10.5 sec
First Copy Out Time Colour
13 sec
Consumables Included
1 x ink cartridge (black) - up to 200 pages ISO/IEC 24711 , 1 x ink cartridge (cyan) - up to 200 pages ISO/IEC 24711 , 1 x ink cartridge (magenta) - up to 200 pages ISO/IEC 24711 , 1 x ink cartridge (yellow) - up to 200 pages ISO/IEC 24711
Limited warranty - 3 years
40 cm
34.3 cm
17.2 cm
8.3 kg
Shipping Width
47.7 cm
Shipping Depth
24.9 cm
Shipping Height
45.7 cm
Shipping Weight
9.8 kg
Sound Emission
53 dBA (operating)
Type: Printer / copier / scanner
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Max Paper Size: A4 (210 x 297 mm)
Max Paper Size: ANSI A (Letter) (216 x 279 mm)
Brand: Brother
