Brother DCP 9010CN Colour Laser All-in-One
Quicklinx: 6LHJWS00 Mfr#: DCP9010CNZU1
Brother's DCP-9010CN is the perfect multifunction printer for the small business, offering you fast results, a wide range of cost-cutting features and professional quality in one space-saving unit.
Brother's advanced toner-based single-pass print technology gives you fast print speeds of up to 16 pages per minute for mono and color. You get crisp, sharp text output and professional-quality color documents.
You can optimize your document management and workflow across your business. Connect the DCP-9010CN to your existing wired network to share it securely among a workgroup and make use of its large 250-sheet paper tray and advanced scanning options. Create professional business documents by enlarging a single page to poster size or adding a watermark to your printouts.
There are numerous ways to reduce your running costs with the DCP-9010CN. You can save paper and toner by printing several pages onto one sheet, or easily restrict user access to certain functions such as color printing.
Add to this the DCP-9010CN's high energy efficiency, low noise levels and recycling-friendly design. Its outstandingly low impact on the environment has been Energy Star certified.
  • Share resources
    Share the DCP-9010CN among several users over your existing wired network for more efficiency and an improved workflow.
  • Reduce paper and toner use
    Reduce 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-up printing.
  • Manage print costs
    With the Color Restriction Tool, an administrator can centrally manage users' access to color printing and bring down costs.
  • Handle multipage documents at the touch of a button
    With the DCP-9010CN's 35-sheet ADF, you can swiftly copy and scan multipage documents.
  • Professional finish
    It's incredibly easy to add a watermark, whether it's a predefined design or a logo of your choice, to your printouts for a professional look.
  • Get the bigger picture - in-house
    For a bigger impact, you can enlarge 1 page to be printed across 4, 9, 16 or 25 A4 sheets with the Poster Printing function in the printer driver.
  • Swift and easy
    Printing on thick paper or envelopes is incredibly simple with the DCP-9010CN's straight paper path. All you have to do is open a small door at the rear for your special media to exit after printing.
  • Be safe
    Print your most confidential documents, safe in the knowledge that they will remain just that, with Brother's Secure Print feature. It's easy to use: when you're ready to print your document, you enter a private PIN code on your computer and click the print button. The document will only print after you've physically entered your PIN code at the printer.
  • Compact build
    With its space-saving, stylish design and small footprint, the DCP-9010CN will easily fit on your desktop.
Brother DCP-9010CN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
LED (colour)
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
147.3 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
35 sheets
Media Size
76.2 x 116 mm (min) - 220 x 406.4 mm (max)
Media Type
Transparencies, plain paper, recycled paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to e-mail
42.8 cm x 49.1 cm x 40.1 cm
22.7 kg
Microsoft Certification
Compatible with Windows 7
1-year warranty
Copier Type
Digital
Printing Technology
LED - colour
Display
2 lines x 16 characters
USB 2.0, LAN
Scan to e-mail
Standard Memory
64 MB 64 MB
Max Supported Memory
576 MB 576 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
First Print Out Time B/W
15 sec
First Print Out Time Colour
16 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Min Original Size
147.3 x 147.3 mm
Max Original Size
Original Type
Sheets, books
35 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
250 sheets
1 sheet
100 sheets
ADF - 35 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - 220 x 406.4 mm weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 16 ppm (A4) - B/W , Printing: up to 16 ppm (A4) - colour , Copying: up to 16 ppm (A4) - B/W , Copying: up to 16 ppm (A4) - colour , Printing: up to 17 ppm (Letter A) - B/W , Printing: up to 17 ppm (Letter A) - colour
1 x USB 2.0 , 1 x LAN
Network Protocols
TCP/IP
Security Protocols & Features
SSL
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows 7, MS Windows Vista, Apple MacOS X 10.3.9 or later
Software Included
ScanSoft PaperPort SE 11.0, Brother MFL-Pro Suite, Presto! PageManager 7
480 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
16 Watt
Warm-Up Time
27 sec
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
24 sec
Limited warranty - 1 year - on-site
42.8 cm
49.1 cm
40.1 cm
22.7 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
6LHJ Brother HL3000 Black 2.2k Toner In Stock £56.43
6LHJ Brother TN230Y - Toner cartridge - 1 x yellow - 1400 pages In Stock £54.52
