This impressive multifunction machine can help you to hit your important deadlines. It offers high-speed printing and copying up to 36ppm – with the first page out in just 8.5 seconds – and delivers consistently professional documents effortlessly.
This versatile all-in-one also boasts cost- and energy-saving features such as a toner save mode and deep sleep mode, as well as an optional high-yield toner cartridge.
If you need professional results fast, the DCP-8110DN is a high-speed office partner you can rely on.
Fast printing and copying
Quickly produce high-quality black and white output at print and copy speeds up to 38 pages per minute. -
Automatic two-sided printing
Print professional two-sided documents, brochures, and booklets using the built-in duplex feature. This feature can help you save money and cut your paper usage by up to 50%. -
Flexible connectivity
Print or scan over your Ethernet network or connect locally via its Hi-Speed USB 2.0 interface. -
Valuable copier features
Includes time-saving copier features such: standalone copying, ID copy, sorting, reduce/enlarge documents from 25-400%, and N-in-1 copying. -
Advanced scanning capabilities
Offers high-quality color scanning and supports a variety of "scan to" functions including: E-mail, file, image, OCR, FTP, and network folder. -
Flexible paper handling
The DCP-8110DN features an adjustable, 250-sheet capacity tray for letter or legal-size paper, plus a 50-sheet capacity multi-purpose tray. -
Cost efficient performance
A high-yield 8,000-page toner cartridge is available to help lower your operating costs. -
35-page capacity auto document feeder
Use for unattended copying or scanning of multi-page documents. -
Convenient walk-up printing and scanning
A USB direct interface is located on the front of the machine for printing files from or scanning files to your USB flash memory drive. -
Advanced security features
This monochrome laser multi-function copier provides a wide range of security features including: secure print, secure function lock, enterprise security and more.
- Brother DCP-8110DN - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Recommended Monthly Volume
- 3500 pages
- Max Copying Speed
- Up to 36 ppm
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 36 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 69.8 x 116 mm (min) - 216 x 406.4 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- 40.5 cm x 41.5 cm x 42.3 cm
- 15.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Laser - monochrome
- 3500 pages
- Display
- 5 lines x 22 characters
- Interface
- AirPrint Enabled
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 320 MB 320 MB
Copying
- Max Copying Speed
- Up to 36 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 36 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, IBM Proprinter, BR-Script 3
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 69.8 x 116 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 69.8 x 116 mm - 216 x 406.4 mm weight: 60 g/m² - 163 g/m² , ADF - 35 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 36 ppm - B/W , Copying: up to 36 ppm - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- IPv4, IPv6
- Operating System Support
- MS Windows XP, Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, Apple Mac OS X 10.7.x
- Software Included
- Drivers & Utilities, Brother BR-Admin Professional, Brother BR-Admin Light for Linux & Macintosh
- 615 Watt
- Power Consumption Standby
- 8.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages , 1 x drum - up to 30000 pages - Brother DR3300
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 40.5 cm
- 41.5 cm
- 42.3 cm
- 15.6 kg
- Shipping Width
- 53.3 cm
- Shipping Depth
- 51.5 cm
- Shipping Height
- 60.1 cm
- Shipping Weight
- 19.7 kg
Brother TN3330 Toner Cartridge - Black | In Stock | £57.26 |
Brother TN3380 Black Toner Cartridge | In Stock | £90.22 |
