Brother DCP 7060D Mono Laser All-in-One
Quicklinx: 81CTWS00 Mfr#: DCP7060DZU1
The compact DCP-7060D delivers outstanding black and white documents while also cutting costs and saving you time around the office.
This efficient and eco-friendly all-in-one machine delivers print speeds of up to 24ppm as well as duplex functionality, while the easy-to-use control panel keeps things simple. A high-yield toner cartridge drives costs down even further, and versatile software facilities mean you'll be even more productive.
So if you want a multifunction printer that creates high-impact documents fast while also reducing costs and your environmental impact, the DCP-7060D is the ideal solution.
  • Versatile
    With high speed printing and copying, the DCP-7060D produces high quality documents fast. A 250 sheet built-in paper tray means you will be replenishing paper less frequently making you more efficient in your daily tasks and the single sheet multi-purpose tray allows you to print on thicker media such as envelopes. The high resolution color scanner means you can create digital copies of hard copy documents quickly and easily.
  • Easy to use
    Although the DCP-7060D is equipped with a wealth of impressive functions, the intuitive control panel together with the 2 line LCD screen means you will be familiar with the most frequently used features in no time. An easy to follow menu structure means the machine is quick and easy to set-up and configure. Replacing the toner cartridge is simple thanks to the front operation.
  • Value for money
    The DCP-7060D is designed to keep print costs to a minimum. Significantly reduce paper consumption with automatic 2-sided printing function. Using toner save mode or the high-yield toner cartridge can further reduce your running costs. Energy Star approval adds to the DCP-7060D's impressive range of environmental features and credentials.
  • Environmentally friendly
    Thanks to its low power consumption, low noise levels and extremely low impact on the environment, Brother's separate toner and drum system significantly reduces waste.
Brother DCP-7060D - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
250 - 1600 pages
Max Copying Speed
Up to 24 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 2400 dpi
Original Type
Sheets
Media Size
76.2 x 116 mm (min) - 220 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0
Office Machine Features
Scan to e-mail
40.5 cm x 39.9 cm x 26.8 cm
10.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Laser - monochrome
250 - 1600 pages
Display
2 lines x 16 characters
USB 2.0
Scan to e-mail
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 24 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 24 ppm
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Original Type
Sheets
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - 220 x 406.4 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - B/W , Printing: up to 10 spm (A4) - B/W duplex
1 x USB 2.0
Operating System Support
Linux, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, Apple Mac OS X 10.4.11 or later
445 Watt
Power Consumption Standby
55 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
7 sec
First Copy Out Time B/W
11 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages - Brother TN2210 , 1 x drum - up to 12000 pages - Brother DR2200
ENERGY STAR Certified
Limited warranty - 1 year
40.5 cm
39.9 cm
26.8 cm
10.1 kg
Shipping Width
52.7 cm
Shipping Depth
51 cm
Shipping Height
44 cm
Shipping Weight
13.2 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
81CT Brother TN2220 - Toner cartridge - 1 - 2600 pages In Stock £52.44
81CT Brother BRO DR2200 DRUM HL2240/2240D/ In Stock £59.53
81CT Brother TN2210 - Toner cartridge - 1 - 1200 pages In Stock £33.94
