Brother DCP 195C Colour Inkjet Multifunction
Quicklinx: 6KTCWS00 Mfr#: DCP195CZU1
In a home office you need big features in a small, low-cost package - and the DCP-195C is ideal. It prints, scans and copies documents quickly and easily, prints directly from USB, media cards or your camera and it even saves you money as well as space with its Energy Star certification and cleverly designed single ink technology. Perfect.
Brother DCP-195C - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 22 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed
Up to 33 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
Scanning
1200 x 2400 dpi
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB, USB host
Office Machine Features
Print from memory card, print from USB flash drive, save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
39 cm x 36.5 cm x 15 cm
7.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
Display
1 line x 16 characters
USB, USB host
Standard Memory
32 MB 32 MB
Supported Flash Memory
Memory Stick, SD Memory Card, xD-Picture Card, Memory Stick PRO, USB flash drive, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Brother Innobella ink
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
36-bit
Document & Media Handling
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
100 sheets
50 sheets
Input tray - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 27 ppm - colour , Copying: up to 22 ppm - B/W , Copying: up to 20 ppm - colour
1 x USB , 1 x USB host
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows 2000 Professional, Apple Mac OS X 10.3.9 - 10.5.x
AC 230 V (50/60Hz)
18 Watt
Power Consumption Standby
3.5 Watt
Power Consumption Sleep
0.6 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site
39 cm
36.5 cm
15 cm
7.1 kg
Shipping Width
46.5 cm
Shipping Depth
46 cm
Shipping Height
22.5 cm
Shipping Weight
9.5 kg
10 °C
35 °C
20 - 80%
6KTC Brother LC-980 Black Ink Cartridge In Stock £13.90
6KTC Brother LC-980 Cyan Ink Cartridge In Stock £7.60
6KTC Brother LC-980 Magenta Ink Cartridge In Stock £7.60
6KTC Brother LC980VALBP - Print cartridge - 1 x black, yellow, cyan, magenta In Stock £33.34
