The Brother DCP-1610W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
Connectivity brings convenience
Enjoy convenience, flexibility and easy connectivity to multiple devices with smart built-in features such as Mobile Printing that simply boost productivity. -
High productivity, less fuss
Eliminate excessive downtime with Brother networking administration tools which provides status monitoring and configuration capabilities. -
Improve productivity and save time
Featuring print speeds up to 20 ppm, higher print speeds save time for multiple users and on large volume printing tasks. Users can utilize their time more efficiently instead of waiting for their printouts.
- Brother DCP-1610W - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Scanning
- 600 x 1200 dpi
- Original Size
- 215.9 x 300 mm (max)
- Original Type
- Sheets
- Media Size
- 148 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- Office Machine Features
- AOSS
- Power
- AC 230 V (50/60Hz)
- 38.5 cm x 34 cm x 25.5 cm
- 7.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, Wi-Fi(n)
- AOSS
- Standard Memory
- 32 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- Windows GDI driver
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 215.9 x 300 mm
- Original Type
- Sheets
- Min Media Size
- 148 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 65 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 148 x 148 mm
- 150 sheets
- 50 sheets
- Input tray - 150 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 21 ppm (Letter A) - B/W
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, TKIP, AES, ARP
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Android, iOS, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.10
- Voltage Required
- 390 Watt
- Power Consumption Standby
- 1.5 Watt
- Power Consumption Sleep
- 0.9 Watt
- First Copy Out Time B/W
- 16 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 10000 pages - Brother DR1050
- IEC 60825-1:2007
- ENERGY STAR Certified
- 38.5 cm
- 34 cm
- 25.5 cm
- 7.2 kg
- Shipping Width
- 48.1 cm
- Shipping Depth
- 43.6 cm
- Shipping Height
- 40.6 cm
- Shipping Weight
- 9 kg
- Sound Emission
- 32 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother Drum Unit 10K | In Stock | £47.74 |
Brother Toner Cartridge | In Stock | £30.73 |
