Brocade offers a unique set of high performance, reliable, and cost-effective optical transceiver that help enterprises and service providers meet the challenges of diverse network topologies. To ensure maximum quality, Brocade selects and tests the most reliable, high-performing optical transceivers on the market, and then warrants their availability, capacity, and performance in Brocade products.
Extensive performance and reliability testing reflects an ongoing commitment to quality. Brocade tests transceivers using the industry's advanced tools and instruments to help ensure that they provide the right mix of functionality and performance when used in conjunction with Brocade product. The speed, capacity, reliability, and low cost of ownership that Brocade is known for is also provided in all optical components.
- Ruckus - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-USR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 100 m
- 1.5 cm x 5.7 cm x 1.2 cm
- Designed For
- Brocade ICX 6430-24, 6430-24P, 6430-48, 6430-48P, 6430-C12, 6450-24, 6450-24P, 6450-48, 6450-48P, 6450-C12-PD, 7750-26Q, 7750-48C, 7750-48F
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-USR
- 10GbE
- 10 Gbps
- 850 nm
- 100 m
- Hot swap module replacement, full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- 1 x Ethernet 10GBase-USR - LC multi-mode
- Compatible Slots
- 1 x SFP+
- UL 60950, CSA 22.2 No. 60950, RoHS, EN 60825, IEC 60825-1
- 1 Watt
- 1.5 cm
- 5.7 cm
- 1.2 cm
- Designed For
