Bretford PureCharge Cart 20
Quicklinx: B7K9WS00 Mfr#: HGFN2ZM/A
The PureCharge Cart 20 is part of the first family of charge-only solutions that are ready to go without the need to add cables or power adapters included with your devices. With the convenience of pre-installed Lightning cables and no setup required, the PureCharge products saves valuable time and money while freeing up cables and power adapters for use elsewhere in your deployment.
  • Simultaneous charge
    Provides simultaneous charging for up to 20 devices.
  • Ready to go
    With pre-installed Lightning cables, simply plug in the cart and it's ready to go, right out of the box.
  • Optimized cables
    Cable clutter is eliminated through custom cables that are the optimal length for each slot and the right-angled Lightning connector makes it easy to connect devices.
  • At-a-glance status
    Without removing them from the slot, instantly determine which devices are fully charged via the individual charge status LEDs.
  • Scalable
    The PureCharge family of products is designed to grow with your organization. Stations can be stacked and the Cart 20 is upgradeable to 40 device slots.
Bretford PureCharge Cart 20 HGFN2 cart - for 20 tablets - platinum powder
Cart
92.2 cm x 55.4 cm x 97 cm
69.3 kg
Recommended Use
20 tablets
Outlets Qty
20
Material
Steel
Platinum powder
7 years warranty
92.2 cm
55.4 cm
97 cm
69.3 kg
Material
Steel
Platinum powder
AV Furniture
Cart
Recommended Use
20 tablets
Cart Functionality
Charge
Output
2.1 A
Outlets Qty
20
Limited warranty - parts - cart - 7 years , Limited warranty - electrical components - 7 years
