Bretford PowerSync Tray
Quicklinx: 9KZ2WS00 Mfr#: HB717ZM/A
Designed for iPad, and compatible with iPhone and iPod touch, the Bretford PowerSync Tray for iPad neatly stores and charges up to 10 devices, keeping your technology tools organized, elegant, and ready to go when you are.
  • Full-rate charging for each device
    The PowerSync Tray for iPad allows you to store, charge, sync, and secure up to 10 iPad devices at a time. It provides full 2.1A DC charging power to each iPad.
  • Get in sync, stay in sync
    But in addition, the PowerSync Tray for iPad also supports syncing your iPad devices with iTunes, allowing you to manage the apps, music, movies, books, and podcasts on each device. The PowerSync Tray for iPad also supports charging and syncing of other iOS devices such as iPhone and iPod touch.
Bretford PowerSync Tray cabinet unit - for 10 tablets
Cabinet unit
47 cm x 42.67 cm x 14.73 cm
11.2 kg
Recommended Use
10 tablets
47 cm
42.67 cm
14.73 cm
11.2 kg
AV Furniture
Cabinet unit
Recommended Use
10 tablets
Lockable, battery status indicator
