Prepare and configure up to 20 devices at a time with the Bretford PowerSync D20. Built on Bretford's reliable PowerSync platform, the D20 offers easy access to 20 USB ports, each of which provides full-rate charging for any iOS device. When you're ready, plug in your Mac, and use iTunes or Apple Configurator to activate, name, update, restore, and configure any combination of iPad, iPhone, or iPod touch.
Large Scale Processing
The PowerSync D20 was designed to work with Apple Configurator, allowing you to prepare, supervise, and assign up to 20 devices at a time.
Portable Config Station
The PowerSync D20 offers a carrying handle on top of the device, and includes a storage bag with plenty of room for the device stands and the included cables. Bring the deployment station to the users, and offer the latest settings for your organization, or setup a deployment station in any available space. The D20 is ready to go when you need it, and easy to store when you don't.
Full Rate Charging
The PowerSync D20 offers full-rate charging for all Apple iOS products, including 2.1A for iPad, so your devices will charge in the quickest time possible.
Supports All Devices
The PowerSync D20 works with all models of iPad, iPhone, and iPod touch, including those with Apple's new Lightning connector. Plug in any combination of devices, and let Apple Configurator prepare and conform them accordingly.
Daisy Chain On Demand
For larger deployments, the PowerSync D20 offers an additional USB port. Use this port to daisy chain up to three D20's, and attach up to 60 devices to your Mac.
LED Charge Indicators
Each port on the PowerSync D20 has an LED charge status port. It will glow amber when charging, and green when fully charged.
Works With Configurator
The PowerSync D20 works with Apple Configurator, allowing you to prepare and conform your devices according to your organization's needs.
- Bretford PowerSync D20 (Lightning) charging station - 20 x 4 pin USB Type A
- Product Type
- Charging station
- 15 cm x 41 cm x 9 cm
- 4.4 kg
- Graphite
- Output Connector Type
- Total 20: 20 x 4 pin USB Type A
- Power Device Details
- 20 x - 4 pin USB Type A - 2.1 A
- Cables
- Power cable , USB cable , 20 x Lightning to USB cable
- Product Type
- Charging station
- Designed For
- Phone, portable player, tablet, mobile phone, player
- 15 cm
- 41 cm
- 9 cm
- 4.4 kg
- Enclosure Colour
- Graphite
- Output connectors
- 20 x 4 pin USB Type A - 2.1 A
- Daisy-chaining, carrying handle
- Included Accessories
- Storage pouch, 2 x 10-slot storage racks
- Cables Included
- UL 60950
