Optimized Charging Power
This design features the industry's first 30-device power system designed for iPad, providing full 2.1A DC charging power to all iPad devices. And when connected to your Mac, the PowerSync Cart 30 for iPad automatically switches over to a USB mode for simultaneous syncing.
30 iPad Sync Over 1 USB
The PowerSync Cart 30 for iPad allows you to connect up to 30 iPad devices to your Mac, allowing you to simultaneously install apps, books, videos, music, and Podcasts to each iPad, according to your specifications.
LED Charge Status Overview
While charging, the Charge Status LEDs, located on top of the cart, indicate the charge status of each group of 10 iPad devices, numbered 1-10, 11-20, and 21-30. When all the iPads in a given group are charged, the corresponding LED will change from amber to green.
Laser-Cut Numbering System
The PowerSync Cart 30 for iPad features a laser-cut numbering system, helping you keep your iPads organized in the cart. Each slot features an included 30-pin (H3635 models) or Lightning (HB716 models) to USB cable for charging and syncing.
Works With Configurator
The PowerSync Cart 30 for iPad works with Apple Configurator, allowing you to prepare and conform your devices according to your organization's needs.
Designed For Use Around The World
We have designed and certified the PowerSync Cart 30 for iPad to be used almost anywhere. Check availability in your region using the Where To Buy tool below.
Connector: Lightning 30-pin
Weight & Dimensions:
Weight: 168lbs
Cart Dimensions (WxDxH): 33"x24"x37" (838.2mm x 609.6mm x 939.8mm)
Slot Dimensions (WxDxH): 0.81"x9.5"x12" (20.57mm x 241.3mm x 304.8mm) - Will My Case Fit?
Power: AC: 5.5A Max Draw DC: 2.1A to each iPad
