Precise climate control at the tap of your app. Easily set the heating in your home with the Radiator Thermostat for your own zonal heating system in each room and an integrated timer.
The Bosch Smart Home outdoor siren provides preventive protection and raises the alarm in 3 ways in the event of a break-in. Round out your Bosch Smart Home alarm system – for perfectly coordinated all-round protection indoors and outdoors.
Flexible use
Can be installed sustainably and wirelessly anywhere in the house and quickly ready for operation thanks to the glass solar panel with back-up battery or alternatively using 230 V (AC) or 5-28 V (DC).
Alarm raised in 3 ways
The outdoor siren raises the alarm in 3 ways: audibly at a volume of up to 100 dB, visibly through flashing red LED lights and you are also simultaneously informed while out and about thanks to a push notification from your alarm system.
Smart addition
Compatible with existing wired alarm systems: the siren supplements this with a modern design and makes your conventional alarm system smart.
It is no accident that most alarm systems include sirens: a highly visible outdoor siren on the house generally wards off uninvited guests from a distance.
If there is still an attempted break-in, then the stylish Bosch Smart Home outdoor siren also simultaneously raises the alarm in 3 ways:
Acoustic: through the siren with 3 individually adjustable volume levels up to 100 dB
Visual: through conspicuous flashing red LED lights
Smart: through a push notification from your alarm system to your smartphone
As a result, not only your neighbours are immediately informed – you yourself can inform the emergency service instantly while you are out and about.
Reliably protected against sabotage
Your Smart Home siren cleverly protects itself if someone tries to "do away with it".
Thanks to 2-way tamper protection, it reacts to being pulled off the wall or disconnected from the mounting plate without authorisation in two ways:
All Smart Home users immediately get a push notification via the app.
If the alarm system is activated, then the siren sounds and the red LEDs simultaneously start to flash.
Operates via solar panel or with a power supply
When mounting your outdoor siren, you have the choice:
You can operate your Bosch Smart Home siren wirelessly and sustainably with the high-quality, glass-protected solar panel.
Or you can also connect the outdoor siren in a conventional manner using a 230 V power line or low voltage line (5-28 V).
The integrated mounting plate and the step-by-step instructions in the app make mounting child’s play.
Box contents
1 Siren
1 Battery pack
1 Mounting plate
1 Installation guide The integrated mounting plate and the step-by-step instructions in the app make mounting child’s play.
- Bosch Smart Home - siren
- Product Type
- Siren
- Environment
- Outdoor
- Power Source
- Power adapter, solar
- Siren Sound Level
- 100 dB
- 2-year warranty
- 24.9 cm x 7.9 cm x 15.9 cm
- Product Type
- Siren
- Environment
- Outdoor
- Power Source
- Siren Sound Level
- 100 dB
- Build-in backup battery
- Included Accessories
- Battery pack, mounting plate
- Voltage Required
- AC 230 / DC 5-28 V
- Warranty
- 2-year warranty
- 24.9 cm
- 7.9 cm
- 15.9 cm
- Shipping Width
- 10.2 cm
- Shipping Depth
- 18.1 cm
- Shipping Height
- 27.1 cm
- Shipping Weight
- 1.3 kg
