Bosch Light/Shutter Control
Quicklinx: GY97WS00 Mfr#: 8750002078
£54.16 ex VAT
£64.99 inc VAT
Smart Home light control: Makes existing light switches smart Your smart light switches look completely ordinary. But there s something no one can see: Behind the ordinary-looking switch is the Bosch Smart Home light control. This means that you can also control your light via app, voice command, switch, and much more for more convenience, sustainability and safety.
Flexible control of your lighting With the Bosch Smart Home light control, you can make your existing lighting smart and control up to 2 switch circuits separately via the normal switches, but also via app, voice command and many other options.
Versatile in use Smart light switch Or would you rather have smart controls for your shutters, Venetian blinds or sun blinds The smart helper can do it all! You choose the purpose during installation and you can also change it later if you need to.
Install out of sight Your Smart Home adapts to suit your house: Simply integrate your light control behind existing switches, in junction boxes or even outdoors with the aid of waterproof installation boxes.
Operate your lights conveniently using your voice With your Smart Home light control, you can control selected functions of your lighting conveniently using voice commands with the voice assistants Amazon Alexa, Google Assistant or Siri: Hey Siri / Hey, Google / Alexa, switch on the light. With just one command, you can illuminate every room in your home with ease while cooking, while at the dining table or from your sofa.
Control your lights however you like You can continue to control your lights via the existing switches but thanks to the Bosch Smart Home light control underneath, these are now smart light switches. This means that you can enjoy additional possibilities of controlling your lights, such as: -voice assistants -custom scenarios and automations -timers -or via app at home as well as when you re outAfter installing the smart light control, you can continue to use the existing wall switches/buttons without an additional adapter. No switch is needed if you wish to install it in a junction box.
Enjoy more safety and security Smart lights don t just make your home cosy and comfortable they also make it safer and more secure.Pre-configured services switch your lights on automatically in certain hazard situations.A motion light reduces the risk of accidents in dark corners for you and your loved ones.The presence simulation lights make your home look occupied at any time, scaring off any burglars.In the break-in protection alarm system , an illuminated light alerts you of unwanted guests and scares them off.In the fire safety alarm system , smart lights are automatically switched on to illuminate escape routes.
Optimise your energy consumption Don t give the energy guzzlers a chance! Your smart light control continuously measures the energy consumption of the connected lighting.This means that you can always keep an eye on your current energy consumption.Our tip for saving energy: Try out our Motion light service or the timer function in the app, which switches off the lights automatically after a time defined by you for example, when you have already left for work a while ago.
With child lock & smart protection measures Do you have small children at home who like to play with light switches Thanks to the child lock function in the app, you can easily block your smart light switches from being operated manually.In addition, the built-in device protection function for device temperature and overload provides additional safety and automatically switches off the device if necessary.
Let there be light... or perhaps shade With the light/shutter control II, you can make either your lighting or your shading smart.When incorporating the control into your Smart Home system, simply select Add light control your device is already set to work as a smart light switch.If you would like to change this, after moving house, for instance, this isn t a problem. Click here to find out how you can control your electric shutters, Venetian blinds or sun blinds with your light/shutter control
  • Convenient control of your shading
    Whether you use it as a Smart Home shutter control, Venetian blind control or sun blind control - the smart and versatile tool will put almost any kind of shade into your desired position or tilt it just as you like it.
  • Versatile in use
    Whether as smart shutters, sun blind and Venetian blind control or a smart light switch, if you'd prefer: During installation, you choose how you want to use the smart helper - and can change its use again if you need to.
  • Install out of sight
    Whether behind existing switches or junction boxes indoors, or in weatherproof installation sockets outdoors - the Smart Home shutter control can be installed out of sight anywhere.
Bosch Smart Home Light Control II - light/roller shutter control - ZigBee 3.0
Light/roller shutter control
Placing / Mounting
Flush-mounting, surface-mounting
Power Source
Hardwired
Intelligent Assistant
Siri, Google Assistant, Alexa
Wireless - ZigBee 3.0
Frequency Band
2.4 - 2.4835 GHz
4.05 cm x 2.2 cm x 4.7 cm
Power Source
Hardwired
Placing / Mounting
Max Range Open Space
70 m
Frequency Band
2.4 - 2.4835 GHz
Internet of Things (IoT)
AC 230 V
Warranty
IP20
4.05 cm
2.2 cm
4.7 cm
42 g
-20 °C
50 °C
Type: Wireless lighting set controller
Compatible With: Siri
Compatible With: Alexa
Brand: Bosch
