The controller is the connecting element or the brain of your Bosch Smart Home System. It bundles all information locally on one device. Your Smart Home Controller organises the communication between the devices in your system, making it possible to connect your smart home. In addition, it functions not only as a smart home control centre, but also as an interface to the Bosch Smart Home app. Use it to control your devices at the touch of a finger and adjust all settings.
Protects your data through local storage
Your Smart Home data is stored locally on the Smart Home Controller by default. Only if you want to benefit from partner services (for example, for voice command), data is transferred to the cloud partner. However, by adding selectively, you remain in full control.
Keeps up to date
Your Home Automation Controller updates itself at regular intervals with automatic and free software updates. This guarantees maximum security and keeps your smart home up to date. Even after the purchase, your smart home receives new functions and thus becomes smarter and smarter.
Provides openness when desired
Your privacy comes first. This is why all system settings are initially set to private by default. If you want to open your Smart Home, for example to use the voice command or for other partners, this is possible without any problems. The decision is entirely yours.
As smart as it gets
The control of individual devices is smart – the intelligent and automatic interaction of several devices is even smarter. The real added value of a smart home is that it thinks for you and makes your everyday life easier by having devices interact automatically. The controller is the brain of your Bosch Smart Home System and forms the basis of this cross-device communication. It enables their interaction in scenarios and automations that control regular processes completely automatically. This is how the topic of interoperability is implemented.
Independent, reliable and fast
Unlike devices from other manufacturers, the Bosch Smart Home Controller does not store your data in a cloud, but locally on the controller itself. By storing all relevant information locally on your Smart Home Controller, your system remains independent and responds quickly to your commands. This guarantees system functionality in the event of an Internet failure: Local execution of functions, scenarios and automations is maintained even without an Internet connection. Your Smart Home System remains reliable and safe – no matter what happens.
Technology for life – the Bosch quality promise
Future-oriented innovations have always been a central focus at Bosch. Our know-how in a variety of fields and our demand for reliable quality have been reflected in our products for over 125 years.
The Smart Home Controller, as well as the software used on it and your Bosch Smart Home app, were developed and manufactured by Bosch employees in Germany.
Box contents
1 Bosch Smart Home Controller
1 power supply unit
1 network cable (RJ45)
1 wall bracket with fixings
1 installation instructions
Easy
With all the possibilities of the Smart Home System, are you losing track? No problem! Bosch makes it easy for you: the starter packages combine the most important devices for your start to a smart home and guarantee you optimal combination options - ideal for beginners. -
Efficient
You can breathe easy, as an optimal indoor climate is ensured. Thanks to the intelligent interaction between the devices of this Smart Home Starter Package, you always enjoy your personal feel-good temperature effortlessly at home, while saving energy at the same time. -
Expandable
The Smart Home Starter Sets are just the beginning. Your system can be expanded as you wish at any time - with Bosch Smart Home devices and the numerous partner products. Create your smart home completely according to your wishes and needs. -
Smart Home Controller - connects your Smart Home System
Your controller forms the heart of your Bosch Smart Home System: It connects all your smart devices with each other and connects them to the Bosch Smart Home App. In the app, you control all your devices and settings and create scenarios and automations - all this is easy as pie and at your fingertips. -
Door/Window contact - how to avoid letting heat go out the window
The Door/Window contact detects open doors and windows and notifies the system of these. In this way, your smart Radiator Thermostats know exactly when you are ventilating and they switch off automatically for this period so that no energy is wasted. When you close the window, the thermostats automatically heat up to your desired temperature again. You can also integrate your Door/Window contact into your alarm system. It then triggers the alarm if windows/doors are opened unauthorized.
- Bosch Smart Home - controller
- Product Type
- Controller
- Power Source
- Power adapter
- Connectivity
- Wireless, wired - Ethernet
- Frequency Band
- 868.3 MHz, 869.525 MHz
- 2-year warranty
- 13.5 cm x 3.5 cm x 12 cm
- Product Type
- Controller
- Power Source
- Power adapter
- Connectivity Technology
- Wireless, wired - Ethernet, USB
- Max Range Open Space
- 100 m
- Frequency Band
- LAN , USB
- Included Accessories
- Power adapter, network cable, wall mount bracket
- Warranty
- 2-year warranty
- IP30
- 13.5 cm
- 3.5 cm
- 12 cm
- 190 g
- Shipping Width
- 18.2 cm
- Shipping Depth
- 10.275 cm
- Shipping Height
- 18.15 cm
- Shipping Weight
- 620 g
- 5 °C
- 40 °C
- 15 - 85%
