Compact performance with three wearing style options. For those who need a discreet, customer-facing headset with class-leading features that boosts productivity and colleague collaboration, the C300-XT offers the best of both worlds. Enjoy premium BlueParrott features in a compact design that comes with a choice of wearing styles.
                Blocks out background noiseWhen your workplace is a busy environment with high levels of disruptive noise and you need to maintain focus while making calls to colleagues or customers, call clarity is of paramount importance. The C300-XT delivers 80% noise-cancellation*, ensuring you can hear and be heard, even in a demanding working environment.
                Talk throughout the dayWhen you work long shifts and need to always be available for colleagues and customers, your headset needs to be capable of working as hard as you do. With up to 10 hours of talk-time and offering up to 13 days of standby time, the C300-XT is truly an all-day solution that won't let you down.
                High performance made compactA discreet, public-friendly headset that also offers class leading productivity boosting features, designed to improve colleague collaboration.
                Customisable Parrott ButtonEnable fast access to your favourite features such as mute, speed dial and more and control the headset your way. The Parrott Button can also be used for push-to-talk conversations.
                Push-to-talkJust tap the Parrott Button for immediate 1-to-1 or group conversations for teams who need effective real-time communications.
                VoiceControlAnswer or reject calls with just your voice, keeping your hands free.
                Three different wearing stylesComfortable and lightweight, the C300-XT comes with a choice of three wearing styles: headband, neckband and ear hook, for maximum flexibility.
                Tough, IP54-rated designFeaturing IP54-rated protection against dust and moisture, the C300-XT has been engineered for all-day wear in hot and cold climates, whether you work indoors or outdoors.
                Works with most Bluetooth-enabled devicesIntegrates with devices from smartphones to hand-held terminals. Use our SDK to enable custom experiences. *Independently verified by CJS Labs San Francisco, CA.
                Wireless rangeUp to 100 metres from paired Bluetooth devices. Connects to two Bluetooth devices at once.
- BlueParrott C300-XT - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- Convertible
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Mono
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Volume, remote control, on/off, answer/end
- 1-year warranty
- Product Type
- 28.4 mm
- 16 mm
- 90.4 mm
- 25.4 g
- Recommended Use
Audio Output
- Convertible
- Wireless
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
- Limited warranty - 1 year
