BlueParrott C300-XT Bluetooth Headset
Quicklinx: FXHCWS00 Mfr#: 204200
Recommended Use: Portable electronics, Computer
Connectivity: Wireless
£89.79 ex VAT
£107.74 inc VAT
Compact performance with three wearing style options. For those who need a discreet, customer-facing headset with class-leading features that boosts productivity and colleague collaboration, the C300-XT offers the best of both worlds. Enjoy premium BlueParrott features in a compact design that comes with a choice of wearing styles.
  • Blocks out background noise
    When your workplace is a busy environment with high levels of disruptive noise and you need to maintain focus while making calls to colleagues or customers, call clarity is of paramount importance. The C300-XT delivers 80% noise-cancellation*, ensuring you can hear and be heard, even in a demanding working environment.
  • Talk throughout the day
    When you work long shifts and need to always be available for colleagues and customers, your headset needs to be capable of working as hard as you do. With up to 10 hours of talk-time and offering up to 13 days of standby time, the C300-XT is truly an all-day solution that won't let you down.
  • High performance made compact
    A discreet, public-friendly headset that also offers class leading productivity boosting features, designed to improve colleague collaboration.
  • Customisable Parrott Button
    Enable fast access to your favourite features such as mute, speed dial and more and control the headset your way. The Parrott Button can also be used for push-to-talk conversations.
  • Push-to-talk
    Just tap the Parrott Button for immediate 1-to-1 or group conversations for teams who need effective real-time communications.
  • VoiceControl
    Answer or reject calls with just your voice, keeping your hands free.
  • Three different wearing styles
    Comfortable and lightweight, the C300-XT comes with a choice of three wearing styles: headband, neckband and ear hook, for maximum flexibility.
  • Tough, IP54-rated design
    Featuring IP54-rated protection against dust and moisture, the C300-XT has been engineered for all-day wear in hot and cold climates, whether you work indoors or outdoors.
  • Works with most Bluetooth-enabled devices
    Integrates with devices from smartphones to hand-held terminals. Use our SDK to enable custom experiences. *Independently verified by CJS Labs San Francisco, CA.
  • Wireless range
    Up to 100 metres from paired Bluetooth devices. Connects to two Bluetooth devices at once.
BlueParrott C300-XT - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics, computer
Headphones Form Factor
Convertible
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Mono
Active Noise Canceling
Microphone
Boom
Controls
Volume, remote control, on/off, answer/end
1-year warranty
28.4 mm
16 mm
90.4 mm
25.4 g
Recommended Use
Audio Output
Convertible
Wireless
Wireless Technology
Bluetooth
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Limited warranty - 1 year
Recommended Use: Computer
Brand: BlueParrott
