BlueParrott B550-XT Mono Bluetooth Wireless Headset
Quicklinx: F171BTBS Mfr#: 204165
Recommended Use: Portable electronics, Car audio
Connectivity: Wireless
Earcover : Monaural
£132.04 ex VAT
£158.44 inc VAT
The most advanced BlueParrott headset on the market, the B550-XT features technology engineered to make life on the road easier than ever. Voice Control Pro™ lets you operate the headset's main features hands-free – all it needs is the command "Hello BlueParrott."
  • Industry-leading noise cancelation
    Blocking out 96% of background noise gives your conversations the quality you've been looking for – ensuring that you're heard no matter what type of high-noise environment you're in.
  • All-day conversations
    With up to 24 hours talk time, and 400 hours of standby time, you won't need to cut short your conversations.
  • Just talk
    When you need your hands to do your job, use your voice to activate the headset and control your calls, GPS directions, music, voice assistants, and more. Complete hands-free use lets you concentrate on the task at hand.
  • All-day comfort
    BlueParrott B550-XT is a fifth generation Bluetooth wireless headset, with a design perfected for all-day wearing. With extra padding on the headband and a larger, more cushioned earcup, the B550-XT gives you the headset experience you need when on the road.
  • Quick control, the way you want it
    Our popular Parrott Button™ lets you customize your favorite features at the touch of a button**. Speed dial, mute, and Push-to-talk capabilities make for quick and easy access to what matters most – your conversations.
BlueParrott B550-XT - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Car audio, portable electronics
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Mono
Impedance
32 ohm
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume
Intelligent Assistant
Siri, Google Assistant
1-year warranty
178 mm
63.5 mm
190.5 mm
165 g
Recommended Use
Protection
IP54, water-resistant
Max Operating Distance
100 m
Audio Output
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Impedance
32 ohm
Max Sound Pressure
123 dB
Simultaneously Connectable Devices Qty
2
Voice control, voice guidance
Microphone
Boom
Headset microphone
Frequency Response
150 - 6800 Hz
Remote Control
Controls
Mute, volume
Connector Type
USB 2.0 (5 pin Micro-USB Type B (power only))
Internet of Things (IoT)
Leatherette ear pad, USB car charger, foam ear pad
Cable Details
USB cable - detachable
Headset battery rechargeable
Run Time (Up To)
24 hour(s)
Standby Time
500 hours
- 1 year
Recommended Use: Car audio
Earcover : Monaural
Brand: BlueParrott
