XSMART CLEANS YOUR HOME WITH EASE
With the Blaupunkt bluebot xsmart robot vacuum cleaner you can clean most floor types. The bluebot xsmart robot supports dry and wet vacuuming. Its gyro mapping will increase the cleaning efficiency and the App will increase a seamless user experience.
STRONG BATTERY
With its strong Li-ion battery the bluebot xsmart robot vacuum cleaner from Blaupunkt can clean up to 180m2 and has an operation time up to 140 minutes. It comes with two interchangeable suction nozzles "rolling brush and normal" and won’t be troubled by pet hair. Blaupunkt bluebot xsmart its strong suction power ranges up to 35Watt and with its low noise <60db it won’t stress out you or your pet.
- Suitable for corners
- Automatic recharge and resume
- For pet hair
- HEPA flter
- Can also be controlled from outdoors via an app on your phone
- Set schedule by app, remote control and robot
- Works with Alexa voice control
- Mopping function
- Interchangeable suction nozzle; normal and rotating brush
- Mapping navigation
You can control the robot from anywhere using the app and easily set a cleaning schedule for the whole week with the "different times possible" app.
The robot cleans systematically using mapping technology and can be tracked using the navigation section in the app.
If the battery runs low, the robot returns to the charging station to recharge and resumes work automatically if a cleaning schedule has been set.
Thanks to the choice of two interchangeable suction nozzles, this robot vacuum cleaner can handle most ?oor surfaces and is also suitable for pet hair.
The mopping function means the robot vacuum cleaner can run a wet mop over the surface after vacuuming.
Thanks to the HEPA flter, this robot is also suitable for people with a dust allergy.
- Blaupunkt Bluebot Xsmart BPK-VCBB1XS - vacuum cleaner - robotic
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Compatible Floor Type
- General purpose
- Cleaning Method
- Dry, wet
- Communications Technology
- Wi-Fi
- Dust Collection
- Bagless
- Operating Autonomy
- 120 min
- Sound Pressure Level (SPL)
- 60 dB
- Voltage
- 100 - 240 V
- Power Consumption
- 35 W
- 35 cm x 35 cm x 9.5 cm
- 3.5 kg
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Vacuum Cleaner Type
- General purpose
- Cleaning Method
- Dry, wet
- Dust Collection
- Bagless
- Filter Type
- HEPA
- Dust Capacity
- 0.5 litres
- Room Navigation
Settings, Controls & Indicators
- Smartphone Compatible
Internet of Things (IoT)
- Wi-Fi
- 60 dB
- Included Tools
- Suction nozzle, side brush (4x), brush suction nozzle
- Included Accessories
- Remote control , Water tank , Charging stand , Power adapter , Dust bin , 2 x HEPA filter , Magnetic strip , Mopping cloth , Mopping module
- Power Type
- Rechargeable batteries
- 120 min
- Battery
- Lithium Ion
- Battery Voltage
- 14.6 V
- Battery Capacity
- 2150 mAh
- Full Charge Time
- 240 min
- Power Consumption
- 35 W
- Main Voltage
- 100 - 240 V
- 35 cm
- 35 cm
- 9.5 cm
- 3.5 kg
