Blaupunkt Bluebot Keeps your Home Clean
The Blaupunkt Bluebot XEasy is a small and easy to operate robot vacuum cleaner. With easy control via remote, app or voice with Amazon Alexa, this small vacuum cleaner is easy to use.
At 7.8cm in height, this robot can reach under most furniture and even into corners with its two side brushes.
Easy Control
Set cleaning schedules for different days and times via the Bluebot Robotics app. You can also use the remote control to drive the robot vacuum cleaner directly to dirty spots.
Voice Activation with Amazon Alexa
You can control your robot using the Alexa voice control function. To use the Alexa voice control function you need to download the Amazon Bluebot Robotics app and you need to have an Amazon Account.
Automatic Recharge and Resume
Flat battery? The Blaupunkt Bluebot recharges itself automatically and will automatically resumes cleaning if a cleaning schedule has been set.
- Blaupunkt Bluebot XEasy VCBB1XE - vacuum cleaner - robotic - blue/white/black
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Compatible Floor Type
- General purpose
- Cleaning Method
- Dry
- Communications Technology
- Wi-Fi
- Intelligent Assistant
- Alexa - indirect
- Dust Collection
- Bagless
- Operating Autonomy
- 120 min
- Sound Pressure Level (SPL)
- 55 dB
- Voltage
- 100 - 240 V
- Power Consumption
- 30 W
- Blue/white/black
- 33 cm x 33 cm x 7.8 cm
- 2.38 kg
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Vacuum Cleaner Type
- General purpose
- Hard floor, low pile carpet
- Cleaning Method
- Dry
- Dust Collection
- Bagless
- Filter Type
- HEPA
- Dust Capacity
- 0.5 litres
- Operating Area
- 120 m²
- Special Features
- Sensor technology
- Pet Hair Removal
- Blue/white/black
Settings, Controls & Indicators
- Programmable Cleaning Intervals
- Scheduling Presets
- Smartphone Compatible
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Wi-Fi
- Alexa
- Voice Controlled
- Indirect
- 55 dB
- Included Tools
- Rotating power brush, side brush (4x)
- Included Accessories
- Remote control , 2 x remote control battery , Charging stand , Power adapter , Magnetic strip , 2 x HEPA filter , Brush cleaning tool , Dust filter , Cleaning brush
- Power Type
- Rechargeable batteries
- 120 min
- Battery
- Lithium Ion
- Battery Capacity
- 2150 mAh
- Full Charge Time
- 4 hrs
- Power Consumption
- 30 W
- Main Voltage
- 100 - 240 V
- 33 cm
- 33 cm
- 7.8 cm
- 2.38 kg
