Blaupunkt Bluebot Xeasy Robot Vacuum Cleaner
Quicklinx: F94NWS00 Mfr#: BPK VCBB1XE
Blaupunkt Bluebot Keeps your Home Clean
The Blaupunkt Bluebot XEasy is a small and easy to operate robot vacuum cleaner. With easy control via remote, app or voice with Amazon Alexa, this small vacuum cleaner is easy to use.
At 7.8cm in height, this robot can reach under most furniture and even into corners with its two side brushes.
Easy Control
Set cleaning schedules for different days and times via the Bluebot Robotics app. You can also use the remote control to drive the robot vacuum cleaner directly to dirty spots.
Voice Activation with Amazon Alexa
You can control your robot using the Alexa voice control function. To use the Alexa voice control function you need to download the Amazon Bluebot Robotics app and you need to have an Amazon Account.
Automatic Recharge and Resume
Flat battery? The Blaupunkt Bluebot recharges itself automatically and will automatically resumes cleaning if a cleaning schedule has been set.
Blaupunkt Bluebot XEasy VCBB1XE - vacuum cleaner - robotic - blue/white/black
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry
Communications Technology
Wi-Fi
Intelligent Assistant
Alexa - indirect
Dust Collection
Bagless
Operating Autonomy
120 min
Sound Pressure Level (SPL)
55 dB
Voltage
100 - 240 V
Power Consumption
30 W
Blue/white/black
33 cm x 33 cm x 7.8 cm
2.38 kg
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
Hard floor, low pile carpet
Cleaning Method
Dry
Dust Collection
Bagless
Filter Type
HEPA
Dust Capacity
0.5 litres
Operating Area
120 m²
Special Features
Sensor technology
Pet Hair Removal
Blue/white/black
Settings, Controls & Indicators
Programmable Cleaning Intervals
Scheduling Presets
Smartphone Compatible
Internet of Things (IoT)
Wi-Fi
Alexa
Voice Controlled
Indirect
55 dB
Included Tools
Rotating power brush, side brush (4x)
Remote control , 2 x remote control battery , Charging stand , Power adapter , Magnetic strip , 2 x HEPA filter , Brush cleaning tool , Dust filter , Cleaning brush
Power Type
Rechargeable batteries
Operating Autonomy
120 min
Lithium Ion
Battery Capacity
2150 mAh
Full Charge Time
4 hrs
Power Consumption
30 W
Main Voltage
100 - 240 V
33 cm
33 cm
7.8 cm
2.38 kg
