The Blaupunkt 32" TV features LED Backlighting to deliver brighter, crisper pictures for your viewing enjoyment.
It includes an integrated Freeview tuner and great connectivity options - making it ideal for any room.This TV features LED back lighting to deliver a brighter, clearer picture quality. LED TVs create greater contrast ratios - making blacks appear blacker - leading to a sharper image. In addition, they also consume less power than similarly- sized LCD and Plasma TVs and are mercury free.
An integrated Freeview tuner will allow you to watch all your favorite shows from over 50 TV and 24 radio stations across the country - without the need for an additional set-top box.
Add to this on this model is the PVR function which allows you to record the shows you cannot afford to miss (Please be advised it does require the use of a USB flash drive)
All you need to do is simply plug your TV into an aerial and scan for channels. You'll also have access to `red button' interactive services such as extra sporting coverage from the BBC and teletext, as well as accessibility features such as subtitling and Audio Description.
A Slim LED style to this TV gives a more stylish look than the bulky LCD style. There are even TV's that are LED that also can have that unattractive bulky side to the TV. However this Blaupunkt TV will really add to the look of your latest tech products with the slimmer style frame.
The USB slot can also be used for looking at your photos , playing music and playing many videos ( dependent of file type) Being HD Ready, this TV will display crisp HD entertainment when connected to an HD source such as a games console or DVD Player when connected via an HDMI cable(sold separately).
Three HDMI inputs ensure you'll have enough ports to allow you to connect a couple of AV sources to your TV such as a home cinema system, games console, Blu-ray player/set-top box or a laptop. You'll also be able to switch between sources in an instant via your remote.
For those who like to get fully immersed in the action or tend to watch TV or play games late in the evening there is a handy headphone port for you to connect any standard headphones saving you from disturbing the rest of the room. If you want to connect your laptop to your TV in order to watch a movie, surf the web in style or showcase a presentation for work, you can easily use this TV as your PC/laptop monitor. Either connect your laptop via the VGA or HDMI port on the TV and sit back and enjoy your media on the big screen.
- Diagonal Size (inches)
- 32 in
- Television / Type
- LED Backlit TV
- Aspect Ratio
- 16:9
- Native Resolution
- 1,366 x 768
- Television / Progressive Scan
- Progressive scanning (line doubling)
- Television / HDMI Ports Qty
- 3
- Interface
- Component, Composite, HDMI, SCART, USB
- Network & Internet Multimedia / Functionality
- Digital audio playback, Digital photo playback, Digital video playback
- TV Tuner / Digital TV Tuner
- DVB-T
- TV Tuner / Teletext
- Contrast Ratio
- 1000000:1
- Display / Colour Support
- 16.7 million colours
- Display / Horizontal Viewing Angle
- 178
- Display / Image Brightness
- 300 cd/m2
- HD Standard
- 720p
- Display / Response Time
- 8 ms
- Audio Output / Output Power / Channel
- 9 Watt
- Power / Energy Class
- Class A+
- TV Tuner / Conditional Access
- Common Interface Plus (CI+) slot
- TV Tuner / Digital TV Service
- FREEVIEW
- Remote Control / Remote Control Technology
- Infrared
- Technology
- LED
- Miscellaneous / Features
- PVR Via USB
- Audio Output / Type
- Speaker(s)
- Audio Output / Speakers Configuration
- Stereo
- Television / Widescreen
- Widescreen
- CE System / Parental Lock
- Television / HDCP Compatible
- Television / HDTV Ready
- Television / Parental Channel Lock
- Television / Viewing Angle
- 178 degrees
