Blaupunkt 18.5" HD Ready LED TV with DVB-T
GREAT SPEC HD LED TV, UNDER £95!
Quicklinx: 9278WS00 Mfr#: BLA-185/54G-GB-1B-TCU-EU
The Blaupunkt 18.5" HD TV boasts a slimline LED screen with built-in Freeview and packs a fair punch in a very handy format - and at a great price! Perfect for smaller spaces like the bedroom or kitchen, this easy to move and easy to place TV is ideal for students and flat-sharers.
Bright & Crisp LED Screen
LED back-lit TVs create greater contrast ratios, leading to a sharper image. They are also slimmer and consume less power than similarly-sized traditional LCDs.
Easily Connect to any HD Sources
Benefit from HDMI or component inputs, so that you can watch your favourite media in High Definition. Simply connect HD sources such as Blu-ray players, HD Digital set-top boxes or Games consoles.
Enjoy HD Entertainment
Enjoy the finest details of your favourite movies thanks to a HD Ready 720p screen resolution. You'll experience HD programmes in all their glory when connected to a HD Ready source.
Easy USB Playback
If you connect a USB storage device into your TV you'll be able to enjoy watching and listening to your downloaded content via your TV's media browser.
Freeview Channels Built-in
An integrated Freeview tuner will allow you to watch all your favourite shows from over 50 TV and 24 radio stations across the country - without the need for an additional set-top box.
Electronic Programme Guide (EPG)
The on-screen TV guide will allow you to see what's on now and next, as well as allowing you to plan your viewing up to 7 days in advance.
Slimline Design
Headphone Port for Private Listening
If you want to fully immerse yourself within the action, or if you want to watch TV later into the evening than your partner, then you'll love the headphone port available on this TV.
Television / Widescreen
Widescreen
LED
HD Standard
720p
Aspect Ratio
16:9
Television / HDMI Ports Qty
1
Television / Analogue Video Input Signals
Component, Composite, SCART
Freeview Bult In
Freeview
Digital TV Tuner / Digital TV Tuner Type
DVB-T
Native Resolution
1,366 x 768
Contrast Ratio
1000:1
Television / Viewing Angle
160 degrees
Diagonal Size (inches)
18.5 in
Display / Image Brightness
250 cd/m2
Power / Power Consumption (On mode)
35 W
Display / Response Time
5 ms
Television / Dynamic Contrast Ratio
5000:1
Component, Composite, HDMI, SCART, USB
TV Tuner / MPEG Decoder
MPEG-2
Network Connection
None
Television / Progressive Scan
Progressive scanning (line doubling)
Remote Control / Type
Remote control
Audio Output / Speakers Configuration
Stereo
Stands & Mounts / Stand Included
Television / HDCP Compatible
Television / HDTV Ready
TV Tuner / Teletext
Dimensions & Weight / Height
356 mm
Dimensions & Weight / Width
463 mm
Dimensions & Weight / Depth
76 mm
Dimensions & Weight / Weight
4.2 kg
