Simple yet stylish, feature-rich yet affordable, Neos is the ideal PC chassis for value seekers and first-time builders. The elegantly crafted mesh front panel brings a clean and uncluttered look to the chassis while bringing a splash of color to brighten up any computing space. Users can look forward to dedicated 3.5" and 2.5" drive racks, and compatibility with graphics cards up to 30 cm long. Neos makes installation easy with tool-free mechanisms and dual dust filters mean quick cleanup. To enable quick file transfers, Neos even comes equipped with a high-speed USB port. Brimming with niceties like an aluminum BitFenix logo badge and a powder-coated interior, Neos brings a colorful and smart design at an eminently affordable price point.
Play with color
Designing a chassis that blends into any environment, yet allows for personal customization was no easy feat. Neos achieves this through a simple yet sophisticated design that comes in a variety of mesh colors to suit individual tastes. Available in both black and white models, Neos is a case that lets users choose the color scheme that best suits their own personal style. -
Enhanced airflow
But the mesh adorning the front of Neos isn't merely cosmetic. Large mesh holes allow for unencumbered airflow to your system components, ensuring that your PC runs as cool as it looks. -
Ample expansion
The well thought-out internal layout of Neos enables ample opportunities for expansion. Dedicated 3.5" and 2.5" drive racks cover your system storage, and also allow room for long graphics cards up to 30 cm in length. Expansion cards can be installed with the seven available PCI slots, and optical drives can be added to the two 5.25" drive bays. -
Easy to build
Getting your system up and running is a breeze with Neos. Tool-free hard disk and optical drive installation speeds the setup process along, as do motherboard standoffs that are actually built into the motherboard tray itself. Also, the pull-off front panel with independent I/O panel gives easy access to the front dust filter underneath for quick fan installation. -
SuperSpeed USB 3.0 connectivity
Transferring large media files is quick with Neos, thanks to the included USB 3.0 port that runs up to ten times faster than conventional USB 2.0. -
Incredible extras
Neos offers features that are generally reserved for cases twice the price, including dual removable dust filters for both the front intake and the power supply that keep dust away from your system components. The rolled-edge cable pass-through prevent cable damage during installation, while the aluminum finish BitFenix logo on the front just oozes quality. Offering premium features at a paltry price, Neos is the new benchmark for value cases.
- BitFenix Neos - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black, silver
- I/O Connectors
- 1 x USB 3.0 , 1 x USB 2.0 , 1 x audio
- Supported Motherboards
- ATX, microATX, Mini-ATX
- System Cabinet Features
- Front dust filter, PSU dust filters, tool-less drive bays
- Power Device
- No power supply (ATX / PS/2)
- 18.5 cm x 47 cm x 42.9 cm
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 6
- Front Accessible Bays Qty
- 2
- Black, silver
- Cooling System
- Front: 120 mm fan mount x 2 , Rear: 120 mm fan x 1
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 7
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- 18.5 cm
- 47 cm
- 42.9 cm
