Billion ADSL2+ Firewall Modem/Router
Quicklinx: 7RJ8WS00 Mfr#: BiPAC 5200 RC
An affordable wired 4-port modem/router that offers fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+, higher upload speeds with Annex M, and incorporating a SOHO firewall. In addition an Easy Install CD provides a hassle-free set-up experience - ideal for the home user. The 5200 also works in "half-bridge" mode for passing through your internet connection to a security gateway.
Features:
* High speed internet access with ADSL2/2+; backward compatible to ADSL
* Integrated with 4-port Ethernet Switch, works in "half-bridge" mode
* Firewall Security with DoS Prevention and Packet Filtering
* Annex M compatible
* Ideal for Home and SOHO Users
  • Express Internet access
    The router complies with worldwide ADSL standards. It supports downstream rate up to 12/24Mbps with ADSL2/2+, 8Mbps with ADSL and upstream rate up to 1Mbps. With this technology, users enjoy not only high-speed ADSL service but also broadband multimedia applications such as interactive gaming, video streaming and real-time audio much easier and faster than ever. Particularly, Annex M standard combined in the BiPAC 5200 RC model supports the latest ADSL2/2+ for higher upload speeds by doubling the upstream data rate.
  • SOHO Firewall Security
    Along with the built-in NAT natural firewall feature, the router's advanced anti-hacker pattern-filtering protection feature automatically detects and blocks Denial of Service (DoS) attacks. In addition to the NAT technology, the BiPAC 5200 RC supports packet filtering for high-level security control.
  • Easy network management
    The Web-based User Interface makes the BiPAC 5200 RC extremely easy for users to install and manage the network. The router supports DHCP client and server, enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without re-configuring other stations. Furthermore, future firmware upgrade can be downloaded via the user-friendly Web-based Interface.
Billion BIPAC 5200 RC - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Network / Transport Protocol
PPPoE, PPPoA, AAL5, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2
Firewall protection, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, packet filtering, dynamic DNS server, VPN passthrough
ANSI T1.413
14.1 cm x 9.1 cm x 3.5 cm
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Data Transfer Rate
100 Mbps
Routing Protocol
SNMP 1, SNMP 2
ANSI T1.413, Plug and Play
Built-in Devices
Led panel
Status Indicators
Power, system, link/activity
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
Software Included
Drivers & Utilities
14.1 cm
9.1 cm
3.5 cm
20 - 95%
