Billion 3G/ADSL2+ Wireless 'G' VPN Firewall Modem/Router
Quicklinx: 7RKFWS00 Mfr#: BiPAC 7402GX
A top-quality 4-port wireless 'G' VPN modem/router that features a USB port for additional 3G connectivity using the latest 3G USB sticks and modems from the UK's major 3G service providers. The Dual WAN interface allows automatic failover to 3G should your fixed line internet go down, with auto detect switch back for when your ADSL is reconnected. The 7402GX can also be used in 3G mode only, creating a portable hotspot for sharing your 3G connectivity wirelessly among multiple users wherever you go - at exhibitions, conferences, on the road, anywhere without fixed line connectivity. In addition the 7402GX incorporates a business-class firewall, and IPSec VPN technology embedded for up to 16 private encrypted tunnels, and in fixed line mode offers fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+ and higher upload speeds with Annex M. Billion's renowned built-in Quality of Service (QoS) feature for bandwidth management and traffic prioritization makes this an ideal model for the SOHO or small business user who is serious about secure remote access.
Features:
* Triple WAN interface for ADSL2/2+, cable/fibre and 3G connection, IPv6 support
* Auto-failover feature to ensure an always-on connection
* One USB slot for inserting a 3G USB modem for creating your own portable hotspot
* Works with Vodafone, Virgin, 3, EverythingEverywhere and O2
* 54 Mbps Wireless AP with WPA / WPA2 support and integrated 4-port Ethernet Switch
* 16 IPSec VPN tunnels with powerful 3DES accelerator
Billion BIPAC 7402GX - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL over ISDN, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 16
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, DHCP, POP3, OAM F4, OAM F5
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 3, HTTP
Firewall protection, DMZ port, DHCP support, NAT support, MDI/MDI-X switch, VPN support, MAC encapsulation routing, VLAN support, IGMP snooping, Syslog support, SPI, DoS attack prevention, packet filtering, dynamic DNS server, DiffServ support, manageable, VPN passthrough, WDS support, URL filtering, firmware upgradable, SNTP support, IPSec over WLAN, QoS, virtual server support, WPS, DHCP server
IEEE 802.11b, IEEE 802.11g, UPnP
18.5 cm x 12.4 cm x 3.6 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 16
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, WPA-PSK, WPA2-PSK
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) U-R2
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x
Aerial
Aerial
External detachable
Antenna Qty
1
Gain Level
2 dBi
External power adapter
1 x modem cable , 1 x network cable
18.5 cm
12.4 cm
3.6 cm
20 - 95%
