Billion 3G/ADSL2+ Wireless 'G' Firewall Modem/Router
Quicklinx: 7RKHWS00 Mfr#: BiPAC 7402GXL
The only 4-port wireless 'G' modem/router in the UK designed specifically with failover capability for the 3G home and SOHO user that features a USB port for additional 3G connectivity using the latest 3G USB sticks and modems from the UK's major 3G service providers. The Dual WAN interface allows automatic failover to 3G should your fixed line internet go down, with auto detect switch back for when your ADSL is reconnected. The 7402GXL can also be used in 3G mode only, creating a portable hotspot for sharing your 3G connectivity wirelessly among multiple users wherever you go - at exhibitions, conferences, on the road, anywhere without fixed line connectivity. In addition the 7402GXL incorporates a business-class firewall, and in fixed line mode offers fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+ and higher upload speeds with Annex M. Billion's renowned built-in Quality of Service (QoS) feature for bandwidth management and traffic prioritization makes this an ideal model for the prosumer, SOHO or small business user who wants to share their 3G mobile broadband wirelessly or who requires 3G back-up to their fixed line ADSL.
Features:
* Triple WAN interface for ADSL2/2+, cable/fibre and 3G connection, IPv6 support
* Auto-failover feature to ensure an always-on connection
* One USB slot for inserting a 3G USB modem for creating your own portable hotspot
* Works with Vodafone, Virgin, 3, EverythingEverywhere and O2
* 54 Mbps Wireless AP with WPA / WPA2 support and integrated 4-port Ethernet Switch
* Business-class Firewall Security with DoS Prevention and SPI
  • Communication flexibility via 3G/HSDPA using the USB port
    The BiPAC 7402X series allows you to connect a 3G/HSDPA USB modem to its built-in USB port, enabling you to use a 3G/HSDPA, UMTS, EDGE, GPRS, or GSM Internet connection. With the increasing popularity of the 3G standard, communication via the BiPAC 7402X series is becoming more convenient and widely available -allowing you to watch movies, download music on the road, or access e-mail no matter where you are. You can even share your Internet connection with others, no matter if you're in a meeting, or speeding across the country on a train.
  • Always online
    The BiPAC 7402X series is compliant with worldwide ADSL standards, and supports download rates of up to 12/24Mbps using ADSL2/2+, 8Mbps using ADSL and an upload rate of up to 1Mbps. Using this technology you'll be able to enjoy high-speed ADSL and broadband multimedia applications such as interactive gaming, video streaming and real-time audio. The integrated Annex M standard supports ADSL2/2+ for higher upload speeds by doubling the upload data rate. Planned support for auto-failover means that you'll be assured of a constant Internet connection - in case your ADSL line fails, the BiPAC 7402X series will connect via 3G to deliver uninterrupted connectivity.
  • Double-layer protection
    An integrated 802.11g wireless access point offers quick yet easy access with data encryption for added security. Wireless Protected Access (WPA-PSK/WPA2-PSK) and Wireless Encryption Protocol (WEP) support ensures high-level data protection and WLAN access control. In addition, rich firewall security features such as SPI, Dos attack prevention and URL content filtering are integrated to provide unparalleled protection for Internet access. Enjoy the benefits of added security by simply pressing the Wi-Fi protected setup button to quickly and easily set up secure wireless communication. If your network requires wider coverage, the built-in Wireless Distribution System (WDS) repeater function allows you to expand the wireless network without the need for using any wires.
Billion BIPAC 7402GXL - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL over ISDN, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, PPPoA, AAL5, DHCP, POP3, OAM F4, OAM F5
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 3, HTTP
Firewall protection, DMZ port, DHCP support, NAT support, MDI/MDI-X switch, MAC encapsulation routing, VLAN support, IGMP snooping, Syslog support, SPI, DoS attack prevention, packet filtering, dynamic DNS server, DiffServ support, manageable, VPN passthrough, WDS support, URL filtering, firmware upgradable, SNTP support, QoS, virtual server support, WPS, DHCP server
IEEE 802.11b, IEEE 802.11g, UPnP
18.5 cm x 12.4 cm x 3.6 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, WPA-PSK, WPA2-PSK
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) U-R2
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x
Aerial
Aerial
External detachable
Antenna Qty
1
Gain Level
2 dBi
External power adapter
1 x modem cable , 1 x network cable
18.5 cm
12.4 cm
3.6 cm
20 - 95%
