Billion 3G/ADSL2+ VPN Firewall Modem/Router with Auto-Failover
Quicklinx: 7RJCWS00 Mfr#: BIPAC 7402X
A top-quality 4-port wired VPN modem/router that offers fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+, higher upload speeds with Annex M, incorporating a business-class firewall, and IPSec VPN technology embedded for up to 16 private encrypted tunnels. Billion's renowned built-in Quality of Service (QoS) feature for bandwidth management and traffic prioritization makes this an ideal model for the SOHO or small business user who is serious about secure remote access. In addition the 7402X features a USB port for additional 3G connectivity using the latest 3G USB sticks and modems from the UK's major 3G service providers. The Dual WAN interface allows automatic failover to 3G should your fixed line internet go down, with auto detect switch back for when your ADSL is reconnected.
Features:
* Triple WAN interface for ADSL2/2+, cable/fibre and 3G connection, IPv6 support
* Auto-failover feature to ensure an always-on connection
* Works with Vodafone, Virgin, 3, EverythingEverywhere and O2
* One USB slot for inserting a 3G USB modem
* 16 IPSec VPN tunnels with powerful 3DES accelerator
* Business-class Firewall Security with DoS Prevention and SPI
Billion BIPAC 7402X - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL over ISDN, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet
VPN tunnels: 16
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, DHCP, POP3, OAM F4, OAM F5
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 3, HTTP
Firewall protection, DMZ port, DHCP support, NAT support, MDI/MDI-X switch, VPN support, MAC encapsulation routing, VLAN support, IGMP snooping, Syslog support, SPI, DoS attack prevention, packet filtering, dynamic DNS server, DiffServ support, manageable, VPN passthrough, URL filtering, firmware upgradable, SNTP support, IPSec over WLAN, QoS, virtual server support, DHCP server
UPnP
18.5 cm x 12.4 cm x 3.6 cm
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
VPN tunnels: 16
Routing Protocol
UPnP
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) U-R2
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x
External power adapter
1 x modem cable , 1 x network cable
18.5 cm
12.4 cm
3.6 cm
20 - 95%
