Billion 2.3 Mbps SHDSL VPN Firewall Bridge/Router
Quicklinx: 7RJFWS00 Mfr#: BiPAC 8500
A high-quality 4-port wired VPN bridge/router that supports the worldwide SHDSL standard for symmetric rates up to 2.3 Mbps (2-wire). Incorporating a business-class firewall, embedded VPN protocols and Billion's renowned built-in Quality of Service (QoS) feature, this an ideal model for the business user.
Features:
* High-speed internet access with SHDSL
* Support Symmetric Data Rate of up to 2.3 Mbps (2-wire)
* Supports Virtual Private Network (VPN) and QoS
* Integrated 4-port Ethernet Switch
  • High-speed Internet access with 2-wire SHDSL
    The BiPAC 8500 complies with the standard of SHDSL for worldwide deployment and supports a symmetric data rate of up to 2.3 Mbps. With the SHDSL technology, the BiPAC 8500 allows office users to enjoy high-speed symmetric bandwidth and multimedia applications such as FTP sharing, video conferencing and real-time audio with much ease and speed than ever before.
  • High-speed back-to-back connectivity
    The BiPAC 8500 can be configured as RT/COT (client/server) mode for back-to-back applications. With the symmetric transmission auto-detect speed of up to 2.3 Mbps, the router can offer a cost-effective way for bandwidth-consuming applications, such as distance learning and video conferencing.
  • Smooth and responsive net connection
    The Quality of Service (QoS) feature helps users to manage the bandwidth and prioritize data transfer effectively. It gives one full control over the traffic of any type of data, ensuring latency-sensitivity and bandwidthconsuming applications such as video conferencing, customer information or FTP sharing, can move through the router at instantaneous speed, even when under heavy tasking. The speed for inbound and outbound data passed through the router can be controlled to ensure that users do not saturate the bandwidth with their browsing activities.
  • SOHO firewall security with DoS prevention and SPI
    Besides having a built-in NAT natural firewall feature, the BiPAC 8500 also provides an advanced hacker pattern-filtering protection that can automatically detect and block Denial of Service (DoS) attacks, such as IP spoofing, ping of death, etc. The router is also built with Stateful Packet Inspection (SPI) to determine whether a data packet should be allowed to pass through the firewall to the private LAN.
  • Virtual Private Network
    The router supports embedded Virtual Private Network (VPN) protocols for users to establish private encrypted tunnels over the public Internet.
Billion BIPAC 8500 - bridge/router - DSL modem - desktop
Bridge/router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
SHDSL
WAN Ports Qty
1
Ethernet, Fast Ethernet
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
Telnet, SNMP 3
Firewall protection, DHCP support, NAT support, VPN support, auto-uplink (auto MDI/MDI-X), Syslog support, SPI, DoS attack prevention, packet filtering, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering
UPnP
18.5 cm x 12.7 cm x 4.7 cm
Bridge/router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
RIP-1, RIP-2
Telnet, SNMP 3
Encryption Algorithm
DES, Triple DES, MPPE, AES, IKE
UPnP
Communications
DSL modem
SHDSL
Protocols & Specifications
ITU G.991.2 (G.shdsl)
Max Transfer Rate
2.3 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x SHDSL , Management: 1 x RS-232
External power adapter
18.5 cm
12.7 cm
4.7 cm
45 °C
20 - 95%
