Best Value Veho Kuzo 007 HD USB Flip Camcorder
Quicklinx: 764WWS00 Mfr#: VCC-007-HD-KUZO
Record your memories in High Definition (HD) resolution with the Kuzo range of camcorders from Veho. Easy to use, point and shoot with 2" screen. Record onto SDHC card ready for easy download onto your PC and YouTube.
The Veho VCC-007 High Definition Camcorder has been designed for the YouTube generation who want a camcorder that fits in the pocket and and can go everywhere all of the time without weighing you down. The Kuzo point and shoot design makes it simple to capture HD footage and, with the flip USB port, upload to YouTube.
Main Features:
  • Digital video image resolution up to 1280 x 720 at 30fps
  • 4x digital zoom
  • Records full motion HD video, H.264 and MOV file formats
  • Retractable USB 2.0 connector for instant internet upload
  • 6cm x 12.5cm x 2.3cm(W x H x D)
  • 93 Grams
  • Records to SD and SDHC Card (Up to 8Gb)
  • Aperture range F/3.1
  • 2 TFT inch display
  • 5MP CMOS Sensor (including stills)
  • AV
