The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Samsung 22x SATA DVD writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media. Our aerodynamic frame design helps to reduce the acoustic noise. You will be amazed how quiet when the drive is running.
- Colour Of Product Black / Beige / Silver
- Interface Serial ATA
- Loading mechanism Tray
- Type DVD±RW (± DL)
- Drive device, buffer size 2 MB
- Mounting Vertical/Horizontal
- Internal
- Lightscribe No
Reading speed
- CD-RW read speed 40 x
- DVD+R Double Layer read speed 12 x
- DVD+RW read speed 12 x
- DVD+R read speed 16 x
- DVD-RW read speed 12 x
- DVD-ROM read speed 16 x
- CD-ROM read speed 48 x
- DVD-R Dual Layer read speed 12 x
- CD read speed 48 x
- DVD-RAM read speed 12 x
- DVD-R read speed 16 x
Weight & dimensions
- Dimensions W x D x H 148.2 x 170 x 42 mm
Writing speed
- CD write speed 48 x
- CD rewrite speed 32 x
- DVD-R Double Layer write speed 12 x
- DVD-RAM write speed 12 x
- DVD+RW write speed 8 x
- DVD+R write speed 22 x
- DVD+R Double Layer write speed 16 x
- DVD-R write speed 22 x
- DVD-RW write speed 6 x
