Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
- Product Description: PULSE 550W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
- Wattage: 550W
- Size: ATX 12V
- Input Range: 230Vac, 10A, 50-60Hz
- Connections: 240 +4 PIN Main Connector x1 / CPU 4-PIN 12V Connector x1 / SATA Connector x2 / 4 PIN Molox Peripheral Connector x3 / Floppy Drive Connector x1
- Additional Features: Power Factor Control (PFC), Silent with better ventilation
- Warranty: 1 Year
