With the massive factory overclock and enhanced Fermi Architecture, Palit GeForce GTX 570 Sonic Platinum can boost 6% higher in DX11 performance than non-OC version. Featuring the dual fan thermal solution and mercury design fan cover, Palit GeForce GTX570 Sonic Platinum remains quiet and cool while you rip through the latest titles. Palit GeForce GTX 570 Sonic Platinum is the king amongst GeForce GTX 570 series!
- Palit Own Design GTX 570
- Sonic Platinum Overclocking Edition
- 8% Higher than non-OC version
- Stylish Mercury Design fan cover
- Dual-Fan thermal solution
- Quieter in 2D stand by mode
- Cooler under 3D loading mode
- Dual Dual-link DVI-I, HDMI, DisplayPort
Key Features
- Microsoft DirectX11 support
- NVIDIA CUDA technology with CUDA C/C++
- DirectCompute 5.0 and OpenCL support
- NVIDIA PhysX technology
- NVIDIA SLI Ready
- NVIDIA 3D Vision Surround Ready*
- NVIDIA PureVideo HD technology
- PCI Express 2.0 support
- Two dual-link DVI-I connectors
- One HDMI 1.4a connector
- One DisplayPort connector
- Dual-link HDCP capable
- OpenGL 4.1 support
Requirements
- PCI Express or PCI Express 2.0-compliant motherboard with one dual-width x16 graphics slot
- One 6-pin and one 8-pin PCI Express supplementary power connector
- Minimum 550W or greater system power supply (with a minimum 12V current rating of 38A)
- Supported Operating Systems: Windows 7, Windows Vista, Windows XP
Dimensions
- PCB: 267mm(L) x 112mm(W)
- Cooler :2 slot
- Bracket: 2 slot
Accessories
- Driver CD
- Manual
- Power Cable
- DVI-CRT Adapter
- Palit GeForce GTX 570 Sonic Platinum - graphics card - GF GTX 570 - 1.25 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 570
- Memory
- 1.25 GB GDDR5
- Core Clock
- 800 MHz
- Effective Memory Clock
- 4 GHz
- Memory Interface
- 320-bit
- 2 x DVI-I (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.1
- 26.7 cm x 11.2 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 800 MHz
- API Supported
- Nvidia SLI Multi-GPU Technology, Dual Slot Fan Cooler, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Dual Fan Design, Mercury Design fan cover, HDCP
- Size
- 1.25 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4 GHz
- Bus Width
- 320-bit
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Required Power Supply
- 550 W
- Additional Requirements
- Two additional power connectors, adjacent PCI slot
- 219 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities
- Supported Windows 7 Features
- Windows Media Center
- 26.7 cm
- 11.2 cm
