Best Value Palit GeForce GT 730 902MHz 1GB DDR3 PCI Express 2.0 HDMI
Quicklinx: 9PJQWS00 Mfr#: NEAT7300HD06-2080H
  • High-Definition Multimedia Interface (HDMI)
Speed up your PC multimedia experience. Upgrade from integrated graphics to the new NVIDIA® GeForce® GT 730 dedicated card and enjoy faster PC gaming, video, photos, and web.
  • Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
  • Designed to work perfectly with the new PCI Express 2.0 bus architecture, offering a future-proofing bridge to tomorrow's most bandwidth-hungry games and 3D applications by maximizing the 5GT/s PCI Express 2.0 bandwidth.
  • Support for HDMI output enables sending both high-definition video and audio signals to an HDTV via a single cable.
  • HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display.
  • Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience.
  • Able to drive the industry's largest and highest resolution flat-panel displays up to 2560 x 1600 and with support for HDCP.
  • Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
Spec
  • Product Number NEAT7300HD06-2080H
  • Memory Amount 1024MB
  • Memory Interface 64bit
  • DRAM Type DDR3
  • Graphics Clock 902
  • CUDA Cores 384
  • Microsoft DirectX 12
  • OpenGL 4.4
  • Bus Support PCI-E 2.0 x 8
  • Certified for Microsoft Windows 7 ?
  • Certified for Microsoft Windows 8 ?
  • Maximum Digital Resolution 2560x1600
  • Maximum VGA Resolution 2048x1536
  • Dual-Link DVI Yes
  • VGA Yes
  • HDCP Yes
  • HDMI Yes
  • Height 2 Slot
  • PCB Width 115mm x 69mm
  • Graphics Card Power 23 W
  • Minimum Recommended System Power 300 W
  • Accessory Manual, Driver Disc
Graphics Processor Manufacturer
NVIDIA
Graphics Processor
NVIDIA GeForce GT 730
PCI Express 2.0
Memory Size
1 GB
Digital Output
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
